Author Topic: AIMTRAK Lightgun - Incorrect movements  (Read 2516 times)
chimera123
  • Last login:November 01, 2015, 04:17:06 pm
« on: September 13, 2015, 03:09:33 pm »
Hello,
Just setup a AIMTRAK Lightgun to my MAME cabinet.
Because the Gun didnīt work properly I decided to install the calibration utility and figured out that all the movements are vice versa.
When I move the gun to the right the red dot move to the left, when I move it up the red dot move down......
Anybody an idea what wrong or which settings needs to be changed?
many thanks
Chimera
lisowskikevin
  • Last login:April 02, 2024, 07:49:55 pm
  • If you take shortcuts, you get cut short.
Re: AIMTRAK Lightgun - Incorrect movements
« Reply #1 on: September 13, 2015, 05:48:50 pm »
Thats normal for the utility, it will see the gun from its perspective thus everything will be flipped. The direction is flipped as you go from up/down left/right.
You don't need to change a setting for that...it is functioning as it should.
noiseprisoner
  • Last login:April 16, 2019, 09:32:35 am
« Reply #2 on: September 14, 2015, 06:42:07 am »
Yep, that happens in the utility and freaked me out at first too. When you go into MAME, it should be fine after you setup the lightgun in the controls
Sent from my LG-V500 using Tapatalk
chimera123
« Reply #3 on: September 14, 2015, 12:35:10 pm »
thanks a lot guys !!!
