Author Topic: Help Identifying I/O Boards  (Read 1081 times)
xodaraP
  • Last login:February 28, 2018, 02:26:20 pm
« on: September 11, 2015, 07:52:36 am »
Hi guys,
I'm trying to get a JVS-PAC setup on my Cyber Lead cab and not having any luck, so I'm hoping someone can identify these I/O boards so I can find out if they are known to not work with the JVS-PAC or if the JVS-PAC/USB cable is faulty. The bottom picture is of the board behind the control panel. Behind the 2 USB cables (I left them plugged in so it stayed powered on) says "Namco JVS Amigo PCB" on it. The other board is directly above the power supply on the back, has 3 VGA/HD-15 cords plugged into it (2 seem to be input, 1 is output to the monitor), and 3 USB cables (1 to JVS/JAMMA adaptor on the front, this is the USB I'm using, 2 more to the other board I've taken a photo of)
And
