Author Topic: .  (Read 4415 times)
ChanceKJ
« on: September 10, 2015, 05:05:23 am »
« Last Edit: March 19, 2021, 12:03:49 am by ChanceKJ »
  • Last login:May 19, 2026, 11:21:47 am
Re: 20EZ Flipped Image Issue
« Reply #1 on: September 10, 2015, 11:15:32 am »
Couldn't you just rotate the tube inside the cage?  :dizzy:
« Reply #2 on: September 10, 2015, 11:19:40 am »
And actually,  I know the 60-1 has a flip screen option. Did you check the documentation on your ArcadeSD?
vwalbridge
« Reply #3 on: September 10, 2015, 11:19:57 am »
Not having cracked open the monitor in my DK....I was scarred to suggest this exact thing.
« Reply #4 on: September 10, 2015, 11:21:01 am »
Right after I posted that, I remembered the flip option on the JAMMA card. I'm pretty sure that's it.
F'n N00b.
« Reply #5 on: September 10, 2015, 11:23:26 am »
Interesting, I just checked, and there is NO screen flipping on the ArcadeSD. But there is on the 60-1. Go figure.
vwalbridge
« Reply #6 on: September 10, 2015, 11:26:36 am »
How about this thread:
http://forums.arcade-museum.com/showthread.php?t=54299
And on the 2nd page of that thread, someone links to 3 other pages for help as well.
This page in particular:
http://www.brasington.org/arcade/tech/flip/
« Last Edit: September 10, 2015, 11:32:56 am by vwalbridge »
« Reply #7 on: September 10, 2015, 11:30:06 am »
No, it's pretty clear on KLOV that board does not, nor will it ever have, screen flip installed. ChanceKJ is going to have to mess with the wiring.
vwalbridge
« Reply #8 on: September 10, 2015, 11:33:44 am »
I also immediately thought his board might be in some sort of 2-player cocktail mode.
« Reply #9 on: September 10, 2015, 01:01:10 pm »
No, some monitors are like that. That's why many JAMMA boards have the option to flip.
ChanceKJ
« Reply #10 on: September 10, 2015, 02:34:01 pm »
« Last Edit: March 19, 2021, 12:03:59 am by ChanceKJ »
« Reply #11 on: September 10, 2015, 03:01:51 pm »
I'm really stuck on trying to figure out why this happened in the first place.
Easy, it's all in how the Sanyo is wired and the way the signal is being output by the board.
Hook up your 60-1, but switch the dip that will flip the image. Should work just fine. The ArcadeSD unfortunately doesn't allow that.
In a Dynamo JAMMA cab, it wouldn't be a problem,  you'd just physically rotate the monitor (they're designed for that). A DK, not so much
ChanceKJ
« Reply #12 on: September 10, 2015, 09:54:36 pm »
« Last Edit: March 19, 2021, 12:04:05 am by ChanceKJ »
« Reply #13 on: September 10, 2015, 10:08:48 pm »
Interesting development. So yep this is definitely an "issue" with the ArcadeSD.  As in yes, it lacks the ability to flip the image, and it looks like on the 20EZ's we need to either rotate the monitor or flip the yoke wires.
I tested it by putting in another game and checking the orientation.  This is kinda lame. I really wish this was an option on the ArcadeSD. kinda a bit of a fail here.
Anyone have good instructions for flipping the 20EZ via the yoke wires? I've read about a few people botching it. I just wanna be sure i'm switching the right colours.
Didn't someone  on KLOV suggest what wires to swap?
Oh, and I was saying this 7 hours ago... :-)
« Last Edit: September 10, 2015, 10:13:09 pm by yotsuya »
ChanceKJ
« Reply #14 on: September 10, 2015, 10:27:46 pm »
« Last Edit: March 19, 2021, 12:04:11 am by ChanceKJ »
« Reply #15 on: September 10, 2015, 10:28:55 pm »
No, something about cutting the yoke?  ...im not sure i want to tinker with that on this monitor. I'd much rather follow the proper instructions from someone who can tell me what wires need to go where.
Oh, and you do get full credit for leading me in that direction Paul. Thanks for that,
Take their advice and check out Bob Roberts ' s site.
« Reply #16 on: September 10, 2015, 10:31:38 pm »
ChanceKJ
« Reply #17 on: September 10, 2015, 10:51:37 pm »
« Last Edit: March 19, 2021, 12:04:17 am by ChanceKJ »
