Author Topic: Paradise led joystick..... sanwa jlf..... / same or dif mount pattern?  (Read 1045 times)
deezdrama
  • Last login:January 25, 2024, 09:45:32 pm
    • forum.arcadecontrols.com/index.php/topic,146268.0.html
Im painting my first cab and undecided wether Im going to go with jlf's or paradise led joysticks.
I have everything painted but cant paint the cp untill i decide on which sticks im going to run because i need to drill/install the threaded inserts on the bottom of my cp.
I have a jlf that I can use as a template to install the threaded inserts.
If I knew the paradise led sticks used the same mounting pattern then i could install my inserts and paint the cp.... but I dont know, ive emailed paradise and pm'd them here but havnt heard back yet and want to get this paint job done this weekend.....
If anyone knows if the jlf and paradise led sticks use  the same or different mounting pattern ....it would be greatly appreciated!
« Last Edit: September 06, 2015, 06:55:22 pm by deezdrama »
