Author Topic: T-Molding Thickness  (Read 1341 times)
Oldskool
  • Last login:November 30, 2007, 06:45:38 pm
  • Puttin' on the foil.
T-Molding Thickness
« on: January 06, 2004, 09:04:31 am »
I'm planning on using 5/8" MDF and laminate (.047") on ONE side.
Is it better to use 5/8" or 3/4" t-molding.
Is 5/8" molding slightly wider than 5/8"?
Can molding, once installed, be trimmed on it's edges? I could use 3/4" and trim the overhang. (sounds risky to me).
%$#@!&* machine took my quarter!
daeven
  • Last login:July 15, 2022, 12:17:33 pm
  • Llama this!
Re:T-Molding Thickness
« Reply #1 on: January 06, 2004, 09:21:04 am »
On my upright cabinet, I used 5/8" MDF with at least .047" of paint.  :)  The 5/8" T-molding looks great.  I'm now working on a cocktail cabinet and have slightly oversized T-molding on the control panel sides.  I have't tried trimming yet, but I don't think I could make it look good.  Maybe a router with a laminate bit?  Has anyone done this?
If you use the 5/8" T-molding, I would suggest that you paint the edges the same color as the sides before installing the T-molding.  That way, you won't be able to easily see any areas that might not be fully covered.
Oldskool
« Reply #2 on: January 06, 2004, 09:41:53 am »
Holy smokes, .047" of paint?
What's that, about 10 coats?   ;D
daeven
  • Llama this!
« Reply #3 on: January 06, 2004, 01:07:16 pm »
I couldn't figure out how to get the fininsh to look smooth.  By the time I got to the second gallon of paint, I tried a thin foam roller amd got a nice finish!
