Author Topic: other sources for U-HID-compatible harness?  (Read 1685 times)
JoeStrout
  • Last login:August 13, 2021, 02:26:49 pm
« on: August 11, 2015, 07:29:51 pm »
The Ultimarc store is closed for a summer holiday, and also needs to charge $16 for a couple of wiring harnesses...
But they look like fairly standard 0.1" spaced headers, is there any other source for compatible harnesses?  Is this something one could get off-the-shelf at Mouser or Digikey, for example (where I need to order my wire disconnects anyway)?
JoeStrout
Re: other sources for U-HID-compatible harness?
« Reply #1 on: August 11, 2015, 10:29:52 pm »
Way too much time searching hasn't turned up anything ready-made, but I wonder if I could make an IDC (insulation displacement connector) ribbon cable, perhaps with something like this.
My main concern is whether I could fit several of these in a row, or whether they would get in each other's way.  But this shop is not far from me, so maybe I'll just take my U-HID down tomorrow and try it!
  • Last login:Today at 02:25:37 am
« Reply #2 on: August 11, 2015, 11:15:49 pm »
Rolling your own from scratch with IDC connectors can be succeptible to intermittent connections IIRC.
Two possibilities you may want to consider.
1.  Paradise's 4-wire harnesses here and/or 2-wire harnesses here -- they will fit side-by-side perfectly on a .1" header
2.  An IDE HDD cable ==>euro-style terminal strip==>pre-crimped wires cut from a JAMMA harness or these
JoeStrout
« Reply #3 on: August 11, 2015, 11:21:37 pm »
Thanks, I will follow those links and have a look-see.
I also found a nifty system at Pololu that lets you quickly and easily make a harness in pretty much any shape... in my case, I'd use this 2x5 housing (five for 69 cents!).
« Reply #4 on: August 11, 2015, 11:43:23 pm »
Looks like the wires from the Paradise 4-wire harnesses would transplant easily into those 2x5's.   ;D
