Author Topic: Pre-Cut solution for bar top vertical arcade?  (Read 7489 times)
BulletProof
  • Last login:July 07, 2016, 05:48:59 pm
« on: August 10, 2015, 03:31:53 pm »
Hi everyone,
I've been looking all over for a pretty decent solution for my vertical arcade bar top. I found one that seems to fit the bill, but it ships from UK which isn't really a problem, but international shipping of something like this kinda makes me weary:
http://www.ebay.com/itm/PVC-BARTOP-ARCADE-MACHINE-1-PLAYER-VERTICAL-D-I-Y-FLATPACK-KIT-60-IN-1-JAMMA-/161786311676?hash=item25ab3733fc
(That said, the price is pretty good!)
Does anyone know of a US-based pre cut kit for a vertical bar top? I'm planning a JAMMA based cabinet. Any help is appreciated!
J
BulletProof
Re: Pre-Cut solution for bar top vertical arcade?
« Reply #2 on: August 10, 2015, 03:41:53 pm »
Ah-ha! Dude, VERY nice cabinet. So glad you're here! This is essentially exactly what I am looking for.
That said, I assume you've probably shipped plenty of these to the States. [Edit: Duh, you are in the states, hence the "that would be me". :) ] Have you had any problems with the distance? Things being chipped or cracked in transit, etc.
I'm actually totally in love with that Minitendo you have...that with some nice T-Molding would be stunning.
Also, any idea how much it might run to get one to California? I'm trying really hard to stay in my budget.
Thanks for any help!!
« Last Edit: August 10, 2015, 03:45:33 pm by BulletProof »
« Reply #3 on: August 10, 2015, 03:58:19 pm »
Very many to the states.  I wrap my pieces in pipe insulator foam, and make sure all the voids in the box are full to prevent shifting.  I've probably shipped a couple hundred, I've had 3 get damaged, and those were with very obvious damage to the box (dropped, or crushed, or both).
You can put a small LCD in the Minitendo vertically.   :cheers:
I'm in AZ, so shipping to CA shouldn't be bad.  Given your zip, I can give you a good idea of cost.
BulletProof
« Reply #4 on: August 10, 2015, 04:15:32 pm »
Excellent. I am in 95060, so not too far from AZ at all.
Is there a way to "easily" angle the board that the LCD mounts to? I'm going for that retro look as much as possible.
Thanks again!
« Reply #5 on: August 10, 2015, 04:19:18 pm »
Thanks again!
Yes.  The kit is designed so you can angle the monitor any way you wish.  You bolt your monitor to the included monitor mount board, choose your angle / position, and then use the included angle brackets to mount the monitor to the sides of the cabinet.
