Author Topic: P360s & 5 Volt Supply  (Read 1651 times)
Oldskool
  • Last login:November 30, 2007, 06:45:38 pm
  • Puttin' on the foil.
« on: January 04, 2004, 09:34:05 pm »
My P360s should arrive soon, and I'm eager to get them up and running.
I've had a look though this forum for ideas on the 5 volt supply.
Some people are using the IPAC, and some the PC power supply (chopping off a molex connector).
Are both suitable solutions? I'm a bit daft when it comes to current ratings.
%$#@!&* machine took my quarter!
Inaba
  • Last login:December 14, 2004, 01:58:48 pm
  • Secret Squirrel
    • Cazic Thule Forums
Re:P360s & 5 Volt Supply
« Reply #1 on: January 04, 2004, 09:54:16 pm »
My dual P360's are hooked up to my IPAC with no problems.
TalkingOctopus
    • My Arcade
« Reply #2 on: January 04, 2004, 09:55:56 pm »
Either should work without a problem.   The red wire is the 5 Volt on the PC molex connector.
« Last Edit: January 04, 2004, 09:56:20 pm by TalkingOctopus »
Hammerbot
  • Last login:September 04, 2005, 10:40:51 am
  • All work and no play...
« Reply #3 on: January 05, 2004, 08:09:52 am »
I took a second power supply out of an old computer.
Take the 5 volts off any of the 4 pin moles.
All my aux power is off the second power supply. So far no problems with it. That keeps the supply for the PC steady no matter what else is happening. I worried more about it when the monitor is rotating than the draw from the P360's...
rdagger
« Reply #4 on: January 05, 2004, 03:16:05 pm »
The P360 should share a common ground with the IPAC.  Also if you use a transformer, I would be careful to insure the voltage is very close to the IPAC.  Many 5V transformers can fluctuate.
Furthermore, the P360's outputs are normally high at 5V until the stick is moved.  This means that 5 volts is normally flowing from the P360 into the IPAC on the Up, Down, Left and Right pins.
Does anyone know how much tolerance the IPAC has for voltage fluctuations on its inputs?
DeathMonk
  • Last login:April 03, 2015, 02:01:12 pm
    • MameStation.3
« Reply #5 on: January 05, 2004, 04:53:15 pm »
I am also drawing the +5v from my IPAC for my 360's..
Now with cup beer holders!
