Author Topic: old arcade restoration  (Read 3215 times)
shumph
  • Last login:December 23, 2003, 05:24:03 pm
« on: January 04, 2004, 07:03:26 pm »
ok i got this old machine everything works great on it but man is the cab i rough shape!
shumph
Re:old arcade restoration
« Reply #1 on: January 04, 2004, 07:03:56 pm »
grrrr
so rough the attachment wont show
DOC
  • Last login:June 30, 2004, 07:16:06 pm
  • I walk in the dark... But why am i afraid?
« Reply #2 on: January 04, 2004, 07:08:49 pm »
where you're going with this? what's your point?  ::)
Learn we must.. Use the force... Abuse blonde woes...!!
shumph
« Reply #3 on: January 04, 2004, 07:09:38 pm »
ok the cab is in bad shape
but the marquee is perfect (yes klov i will upload a better pic of it to you)
and the bezel is also in perfect shape (yeah this pic turned out crappy)
now i have searched and searched and emailed everyone i could think of but the sideart that was on this machine is recorded or saved nowhere :(
so i had to come up with my own
so far i have only penciled it on after sanding and repainting the cab painting it middle of the week i hope and t molding should arrive by tuesday
DOC
« Reply #4 on: January 04, 2004, 07:18:38 pm »
ahhh, in that case i won't be able to help you out  :'(
tho' your cab is nice, all you need is to do is repaint the sides " or whatever you can do about it "
then if you get the sideart for it " put it on " and there you go! slammin' !?
- doc
shumph
« Reply #5 on: January 04, 2004, 07:30:08 pm »
seeing as no one knows what the side art looked like i wont be getting it.
i have repainted it if you look at last few pics
you also see the sideart that i made and am in process of painting on it
DOC
« Reply #6 on: January 04, 2004, 07:34:56 pm »
ohh, i see ;) ..
well. i hope your " own sideart - turns out as expected "
let us all judge it when you're done :)
gl m8 ;)
