Author Topic: URGENT! CRT EMUDRIVER  (Read 2605 times)
MushiMaster
  • Last login:August 07, 2015, 07:14:39 pm
« on: July 28, 2015, 01:24:34 pm »
Hello!
I have just installed CRT Emudriver on windows XP to my ATI HD4650,  ATI driver shows in ( add remove programs but windows says " found new hardware" every time i restart? I am currently connected to my LCD via HDMI and have not connected my CRT yet. Do i let windows install more drivers? how do i stop the "found new hardware" message? Does this mean it was not installed correct? 15khz Resolutions are showing in acrade os I want to connect my CRT asap. Please help  :)
Calamity
  • Moderator
  • Last login:April 08, 2026, 02:30:14 am
  • Quote me with care
Re: URGENT! CRT EMUDRIVER
« Reply #1 on: July 28, 2015, 01:49:41 pm »
The HD cards have a built-in audio device for HDMI that requires its own drivers, so make sure that's what's being found by Windows and allow it to do its thing.
Steps to create a log:
MushiMaster
« Reply #2 on: July 28, 2015, 02:17:10 pm »
Thank you, I let it do its thing and it did indeed say "hd audio drivers" One final thing, i noticed there is no ATI software to adjust the screen brightness, colors, sharpness etc, Is this all something that should be done with your monitor using crt emulator?
MushiMaster
« Reply #3 on: July 29, 2015, 04:27:39 am »
OMG! It works and looks amazing!  :applaud: The diffrence compared to my LCD is huge :o
My only problem is i have overscan at the top and bottom of my screen :(
Paradroid
  • Last login:December 05, 2025, 10:28:19 pm
    • SCART Hunter
« Reply #4 on: July 29, 2015, 05:08:14 pm »
Simply adjust this using either the analog vertical size control on your chassis or the equivalent service menu setting (if your monitor is digitally controlled).
My MAME/SCART/CRT blog: SCART Hunter
