September 11, 2026, 09:11:20 am
Can't see why not. Just map the R, G, B, H-Sync, V-Sync and ground lines from your chassis to the corresponding VGA pins. Tie the RGB and sync grounds (from the VGA connector) together and you should be fine.Sent from my SM-A300Y using Tapatalk
The VGA pins aren't going to change between different video cards so, yeah, should work fine. If you're confident with making cables, you could definitely build your own. Otherwise the Ultimarc product should be a good bet.Do you have a picture of the 6 pin Molex connection? Crimping pins for a header is a little more involved (since you need the right parts and tools) but if you have an existing cable you could splice it and solder the D-Sub connector on the end. Happy to show you how...
I don't have the monitor I just wanted to know if it was possible before I buy it. As soon as I get it, I will update my post.
