Author Topic: Dual monitor big screen guys - please help.  (Read 1912 times)
vettetek
  • Last login:October 05, 2025, 10:53:53 pm
« on: July 11, 2015, 06:43:23 pm »
Im having some real issues with the HLSL on my WIP system. I can get it to work, but it looks like ass on my 50" lcd thats turned sideways. Its kinda dark, doesnt really have a "scanline" look, and kinda has a moire pattern to it.
What settings are you guys using?
Id just like to start with a known working setup.
I asked in a different thread for some HLSL settings but it kinda went unheard.
jamesjones626
  • Last login:March 08, 2025, 01:58:57 am
Re: Dual monitor big screen guys - please help.
« Reply #1 on: July 12, 2015, 05:49:34 am »
try using mamefxui and enable glsl. download Lottes_crt shaders and enable both the regular and the vert as well. I like the look better than hlsl, but try it yourself and see how it suites you.
vettetek
« Reply #2 on: July 12, 2015, 09:19:54 pm »
hmmm...now im confused.... I thought the HLSL is THE ticket these days?
Again - Ive been gone so long from MAME im sure theres been a ton of advancements.
So - where do I find the lotts latest gsl shaders and maybe a tutorial to set it up?
jamesjones626
« Reply #3 on: July 13, 2015, 04:44:02 am »
you can get mamefxui here.
http://mame32fx.altervista.org/download.htm
Lottes shaders can be found here
https://sites.google.com/site/bigbluefrontend/lottesshader.zip
Unzip the Lottes shaders.
install mamefx and be sure you have everything like your roms were it should go.
when you run mamefx got to options at the top, then choose defualt game options. A new window should open up.  Click on Display, change your video mode to Open GL.
click on the Open GL tab on the left. were it it says shader 0, press select shader, choose Lottes_CRT.vsh.
under Shader 1, press select shader and choose Lottes_CRT_VERT.VSH.  Hit OK at the bottom and fire up a game.
vettetek
« Reply #4 on: July 14, 2015, 11:21:25 am »
thanks Ill give it a try...
Thanks for the idea but im really not sold on it compared to some videos Ive seen on HLSL.
So with that being said - im still looking for people to post their settings.
« Last Edit: July 14, 2015, 12:40:04 pm by vettetek »
jamesjones626
« Reply #5 on: July 14, 2015, 12:43:53 pm »
Yep.
Sent from my Z993 using Tapatalk
jamesjones626
« Reply #6 on: July 15, 2015, 11:21:44 am »
here are my settings, i had copied them from another site that i can not remember.
# DIRECT3D POST-PROCESSING OPTIONS
hlsl_enable 1
hlslpath hlsl
hlsl_ini_read 0
hlsl_ini_write 0
hlslini %g
hlsl_prescale_x 0
hlsl_prescale_y 0
hlsl_preset -1
hlsl_write
hlsl_snap_width 1920
hlsl_snap_height 1080
shadow_mask_alpha 0.15
shadow_mask_x_count 1280
shadow_mask_y_count 720
shadow_mask_usize 0.09375
shadow_mask_vsize 0.09375
curvature 0.0
pincushion 0.06
scanline_alpha 1.00
scanline_size 1.00
scanline_height 0.7
scanline_bright_scale 1.5
scanline_bright_offset 0.60
scanline_jitter 0.05
defocus 0.8,0.8
converge_x 0.0,0.0,0.0
converge_y 0.0,0.0,0.0
radial_converge_x 0.0,0.0,0.0
radial_converge_y 0.0,0.0,0.0
red_ratio 1.0,0.0,0.0
grn_ratio 0.0,1.0,0.0
blu_ratio 0.0,0.0,1.0
saturation 1.3
offset 0.0,0.0,0.0
scale 1.0,1.0,1.0
power 1.0,1.0,1.0
floor 0.03,0.03,0.03
phosphor_life 0.0,0.0,0.0
yiq_enable 0
yiq_cc 3.59754545
yiq_a 0.5
yiq_b 0.5
yiq_o 0.0
yiq_p 1.0
yiq_n 1.0
yiq_y 3.0
yiq_i 1.2
