Author Topic: VGA out to CGA monitor?  (Read 2735 times)
John Li
« on: July 14, 2002, 12:13:34 am »
Since a CGA monitor has the same specs as a standard monitor, would it be possible to use Mame -NTSC with a CGA monitor?
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
Re:VGA out to CGA monitor?
« Reply #1 on: July 16, 2002, 12:09:19 pm »
It is possible.  CGA monitors run a 15khz...but have digital inputs.  You have to hack the monitor board and make a connector to the analog pins just after the digital conversion circuit.
Here is a page that details how to make the hack (this is for a specific cga monitor, but the chipsets are pretty much the same on all).
http://www.arcadecollecting.com/info/Samtron_5inch_CGA_to_Arcade.txt
-Dave
