Author Topic: Mini Qbert - [FINISHED]  (Read 63828 times)
CoryBee
  • Bopity Boopy
Re: Mini Qbert
« Reply #80 on: September 17, 2015, 04:38:23 pm »
Friggin nice!
8BitMonk
Re: Mini Qbert
« Reply #81 on: September 17, 2015, 05:44:27 pm »
Great job, love how this turned out!
kiel0909
  • Last login:May 23, 2022, 02:59:10 pm
Re: Mini Qbert
« Reply #82 on: September 18, 2015, 12:03:43 am »
did you print out a template and center punch your speaker hole drilling pattern? or did you draw it out yourself?
Re: Mini Qbert
« Reply #83 on: September 18, 2015, 09:42:37 am »
Really great build and a really great in depth thread.  This is so much better than an aircraft carrier.
vwalbridge
Re: Mini Qbert
« Reply #84 on: September 18, 2015, 10:42:45 am »
Thanks a lot guys! Really appreciate the compliments. You have all done some really top notch work here so I'm just trying to keep up.
I thought about using a template but just realized it was easier to draw it on with a straight edge and compass. I used a center punch to keep the drilling accurate.
vwalbridge
Re: Mini Qbert
« Reply #85 on: September 21, 2015, 12:07:58 pm »
Put some heavy duty rubber feet on the bottom of the cab. They lift the cab up far enough to allow air intake on those vent holes on the right.
A few of the usual suspects used to wire up the inside of my cab.
I need to power my computer, monitor and marquee. So I started with one of the multi plugs. The monitor and computer will plug into this.
Cut one end off and wired up the insulated spade terminals.
Then plugged them into the back of my power socket.
Here is the back side. Those 2 white wires on the left are for the separate switch to power my marquee. (Sometimes I don't want the marquee light on while gaming. )
I'm using these little screw anchors with zip strips to keep all the wires organized.
Cannibalized the power switch wire from a computer and wired it up to my power button
Fed it thought the power hole and screwed it in. The other end plugs into the power switch pin-out on the motherboard.
On the inside of the cab I re-used the computer brass pcb feet and screwed them in the sides.
Here is one last look at my knocker assembly before it gets mounted inside.
Here it the knocker assembly all mounted inside on pcb feet.
Here is the rest of everything wired up.
Here is my usb volume knob
Here is a video of my knocker working with Qbert. (Just wanted to make sure it works one last time before mounting it up)
Vidiot
  • John 3:16
Re: Mini Qbert - Now with working knocker!
« Reply #86 on: September 21, 2015, 12:57:00 pm »
 :applaud: Nice! Looking beautiful.
« Last Edit: September 21, 2015, 05:54:58 pm by Vidiot »
Slippyblade
« Reply #87 on: September 21, 2015, 05:36:16 pm »
I swear, I gotta be doing something wrong.  Every pic I see of the insides of other folks projects looks cleaner than mine.  Even the ones that claim to be "messy" look cleaner than mine.  The guts of my project tend to look like a wire factory exploded.
Oh yeah - this is an awesome build.  :)
Peabo
  • Pinball junkie
    • Virtual Pinball Build
« Reply #88 on: September 21, 2015, 07:56:02 pm »
Great work!
« Reply #89 on: September 21, 2015, 08:04:32 pm »
BorgDog
« Reply #90 on: September 23, 2015, 08:59:50 am »
Awesome project, love the knocker.  I may have missed it somewhere, but what solenoid is that?
My Projects:
vwalbridge
« Reply #91 on: September 23, 2015, 10:44:35 am »
Thanks Slippyblade! I work in IT so cable management comes with the territory.
vwalbridge
« Reply #92 on: September 23, 2015, 10:46:25 am »
 :laugh2:
Harveybirdman get's first place prize for the first "knocker" joke of this thread!  :cheers:
I was getting a little worried about you guys! I thought you were all slipping around here with the jokes!  ;)
vwalbridge
« Reply #93 on: September 23, 2015, 10:48:03 am »
Thanks BorgDog! Here is the exact 12V Solenoid I am using. For only 12v, this thing packs a punch.
So much punch, that I only have it hitting itself and it's loud enough.
vwalbridge
« Reply #94 on: September 23, 2015, 12:33:27 pm »
Here is the rear of my screen/bezel assembly. I simply used electrical tape to adhere the screen to the back of the bezel plexi. This screen was far to delicate to handle any other mounting technique
Here is the front of the assembly. The pcb on the right is the LCD control board running on HDMI.
This is a side-view of it all. Less than about 1/2 inch thick.
Mounted the control board inside the cab with some PCB feet.
Here is the entire assembly mounted inside the cab
« Reply #95 on: September 23, 2015, 01:29:40 pm »
You are easily my favorite new member.
« Reply #96 on: September 23, 2015, 01:39:48 pm »
+1   Love this project, appreciate your style.  I hope your work sets a precedent for future builds, because we need to see more of this kinda work around. :cheers:
vwalbridge
« Reply #97 on: September 23, 2015, 01:57:02 pm »
Thanks guys! Really means a lot coming from experienced collectors/builders such as yourselves. I haven't been doing this hobby for very long but I'm having a blast doing it. Wish I'd started it years ago.
Quite frankly, the real fun comes when I get to post updates and see what people think. It's just so much fun to BS with you guys and give each other crap every once and a while.  :)
« Reply #98 on: September 23, 2015, 02:09:13 pm »
When are you building me the full-size version?
vwalbridge
« Reply #99 on: September 23, 2015, 02:21:31 pm »
You are totally right. I've had a lot of fun doing these mini-builds and they are challenging but I wish that I would have just built them full sized. I didn't really save any money. It takes just as much time. It certainly wasn't easier. And I have no idea why I was worried about them taking up space. Hell, I'd fill my garage with arcades right now if I could.
I can't stop thinking about new builds. Hell...I'm constantly thinking 2 builds ahead and I have not even finished the current build.
« Reply #100 on: September 23, 2015, 03:08:13 pm »
I'm in the middle of restoring a Qbert and love your build.  Your is smaller and nicer than mine.   :applaud:
Your CP turned out fantastic.  Those red buttons in particular are a great touch.
Applied the artwork to my control panel.
vwalbridge
« Reply #101 on: September 23, 2015, 04:01:51 pm »
Thanks wp34! Appreciate it!
Man, you are very lucky to have an original Qbert. They have become VERY popular as of late and it's like a feeding frenzy whenever one pops up for sale. Even the fugly ones.
Speaking of which...why did people beat up Qberts so bad? Man, every time I seen an un-restored Qbert, it's always beat to hell.
Not sure if you have started a "restore thread" here or not but I'd love to follow your progress.
« Reply #102 on: September 23, 2015, 04:19:39 pm »
I have a thread but have not updated it in 4 years.   :badmood:
http://forum.arcadecontrols.com/index.php?topic=103771.0#lastPost
The cabinet is waiting for yellow paint at this point.  For the black I used the same spray paint as you.  Several of your build pictures remind me of my project which is really cool.  In a few days I'll be posting updated pics.
CoryBee
  • Bopity Boopy
« Reply #103 on: September 25, 2015, 03:59:22 am »
I miss when you use to say that to me...
« Reply #104 on: September 25, 2015, 08:30:41 am »
You aint new no more bro, I still love you though :* <3
vwalbridge
« Reply #105 on: September 28, 2015, 10:39:32 am »
For my marquee retainers, I scored and snapped off a 1" piece of kydex.
Then I took that 1" piece of kydex and scored 1/4" edge.
Then bent over that 1/4" edge.
Took a center punch and marked the holes for the screws.
Drilled the holes in the kydex then center punched through the holes into the top of the cab to mark the holes
Removed the kydex and drilled the pilot holes for the screws.
Marquee is now fully mounted with screws I previously painted satin black. No need to paint the kydex. It already has a nice finsh.
I'm getting close to the finish line on this build. Just need to work on software/FE setup now.
Vidiot
  • John 3:16
« Reply #106 on: September 28, 2015, 10:51:54 am »
Beautiful solution for the marquee retainers. Looks great!
Do you buy the kydex material online? eBay perhaps? I might want to get some of that for future projects.
vwalbridge
« Reply #107 on: September 28, 2015, 11:06:31 am »
Thanks Vidiot! Man, I was really racking my brain trying to figure out a solution to these retainers and I sort of came up with this by accident. I just realized that I could carefully score one side and bend it over with out it breaking. It works if you don't bend it on the same side you score it on.
I've purchased all my Kydex Sheets from Amazon.com but you can also get an alternative product called ABS Sheets
Both available on Amazon.com and both come in multiple sheet thickness. Usually penny-thick or half-penny-thickness variants.
Both also are heat bendable with a heat gun. (This can be very tricky though)
« Reply #108 on: September 28, 2015, 11:09:05 am »
That Kydex will say bent like that?
vwalbridge
« Reply #109 on: September 28, 2015, 11:27:26 am »
That Kydex will stay bent like that?
That's the first thing I was worried about. When I came out in the garage this morning, I was expecting it to have sprung right back out but it definitely holds it's shape. I was entertaining the idea of having some metal bent for me but this solution is 100% cheaper.
I certainly wouldn't do this on a full-size cab because it just wouldn't be rigid enough for a longer distance.  But for something this small, it works.
Slippyblade
« Reply #110 on: September 28, 2015, 01:00:52 pm »
That plastic bends beautifully with a little heat.  As thin as that is, a hair dryer would do the trick.  I use similar stuff, much thicker though, when building armor for stick fighting.
« Reply #111 on: September 28, 2015, 01:51:02 pm »
Nerd alert....
 ;)  :afro:
vwalbridge
« Reply #112 on: September 28, 2015, 01:55:43 pm »
Nerd alert....
 ;)  :afro:
We need a LARP-ing thread.
In fact, just the other day I was at a public park and there were about 25 LARPers doing their thing. Full gear, acting, the whole bit. It was everything I've been told...and more. :)
« Reply #113 on: September 28, 2015, 02:32:11 pm »
Thanks for the tip, man! I got a couple sheets of black ABS from my work that I now know what to do with.
Slippyblade
« Reply #114 on: September 28, 2015, 03:46:19 pm »
Yeah - we've covered this before.  Not a LARP.
vwalbridge
« Reply #115 on: September 28, 2015, 05:03:09 pm »
Wow, those guys are not fooling around.  :o
Makes the group I saw at the park look like kids acting out an episode of Dora the explorer.
Slippyblade
« Reply #116 on: September 28, 2015, 05:24:38 pm »
We aren't even the most hard-core, though we are the largest.  If you want to see some serious ---steaming pile of meadow muffin--- - look up "Historical Medievel Battles".  Live steel, full contact, grappling, shield punching, the works.  That one is gaining traction internationally.  They require EMT personnel onsite at all times cause armor penetration isn't uncommon.
Sorry for the thread de-rail.
vwalbridge
« Reply #117 on: November 21, 2015, 03:39:47 pm »
I took a break from Qbert for a while but recently picked it back up and took it to the finish line. Mini Qbert is 100% finished. I have it running the following games in Hyperspin:
- Qbert
- FHMC Qbert (Faster Harder More Challenging)
-Qbert's Qubes
I've had some time to play on it and I'm pleasantly surprised how well it controls. The U360 performs very well for Qbert's unique joystick controls.
A big THANK YOU to everyone that followed my build. I'd also like to send a special "thanks" the following BYOAC members:
sellsellsell2000 for vectoring my Qbert Serial Tag
and
stpcore for the vinyl artwork and translite marquee prints.
vwalbridge
« Reply #118 on: November 21, 2015, 03:40:21 pm »
Here is a flood of final build pictures:
Re: Mini Qbert - [FINISHED]
« Reply #119 on: November 21, 2015, 03:49:41 pm »
Just might be non trad build of year.
