Author Topic: MaLa in MAME v.162 - are there XML issues?  (Read 1680 times)
specfire
  • Last login:April 23, 2016, 10:39:09 pm
  • Shhh...
« on: June 24, 2015, 09:09:27 pm »
I am using MaLa as a frontend.  Before I consider upgrading my MAME version to the new unified model mamedev are using now, does anyone know if MaLa lists will work and if gamelist management works etc?
I understand that the XML tags have changed.  MAME doesn't use <game> anymore but now uses <machine>.
Is this an issue?
How about RomLister support?
Thanks for any information!
Read to your kids, you'll all be better for it.
NOP
  • Last login:September 19, 2017, 08:22:27 pm
  • I stole my avatar.
    • winterMAME
Re: MaLa in MAME v.162 - are there XML issues?
« Reply #1 on: June 25, 2015, 10:07:06 pm »
romlister support is coming soon.  my free time to fix the 162 xml issue is in short supply right now- maybe this weekend, maybe a week from now.
once this is done, RL will be able to convert 162+ xml files back to 161 compatibility, so all lists for all FE's including mala should start working again.
haynor666
  • Last login:Today at 03:49:14 pm
  • retro maniac
« Reply #2 on: June 26, 2015, 09:10:09 am »
I just realized that MAMEWAH will have the same problem  :-\
  • Last login:Yesterday at 10:04:21 am
« Reply #3 on: June 26, 2015, 09:47:51 am »
http://forum.arcadecontrols.com/index.php/topic,145865.0.html
Keep in mind that the xml file is huge and may freeze for a long time while making changes.
Turn wordwrap off.
I don't know if Da'Old Man's plugins have been affected.
I'm sticking with an older version for now.
« Last Edit: June 26, 2015, 09:49:42 am by BadMouth »
