Author Topic: Worth taking the time to switch from avga3000 to crt_emudriver?  (Read 2822 times)
darryldale
  • Last login:March 07, 2016, 12:54:14 pm
OK, so I've got groovymame running in my MK cabinet and for the most part I am happy with it.
The cab has a 15khz arcade monitor in it.
Is it worth taking the time to switch from the current avga3000 to an ati card running crt_emudriver?
What benefits is there to taking the time to do that? If it is worth doing I would probably pick up a new faster dual core machine to use with it so as not have to mess with the existing pc.
bulbousbeard
  • Last login:August 25, 2015, 11:58:25 pm
Re: Worth taking the time to switch from avga3000 to crt_emudriver?
« Reply #1 on: June 15, 2015, 09:14:21 am »
Yes, it's worth it. The ArcadeVGA doesn't even run most games at the proper refresh rate.
darryldale
« Reply #2 on: June 15, 2015, 10:41:15 am »
Well I'll probably do it then if for no other reason than the fact that my list of items I can screw around with in my spare time is kind of lacking at the moment.
I'm going to pick up an ATI Radeon HD 4870 tonight and will then hunt around for a half decent core2duo machine to throw it in.
sean_sk
  • Last login:August 06, 2019, 10:27:48 am
  • If quizzes are quizzical, then what are tests?
« Reply #3 on: June 16, 2015, 10:39:54 am »
When you say "most games" do you mean mainly MAME arcade roms? Or are you including games from other emulators in UME? Do you have any examples?
« Last Edit: June 16, 2015, 10:45:05 am by sean_skroht »
sean_sk
« Reply #4 on: June 16, 2015, 10:43:42 am »
Double post.
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #5 on: June 17, 2015, 05:13:54 am »
There is no need for this, the mismatch on almost all games is miniscule, for example the difference between 60Hz and 60.05 Hz and would not cause any difference in gameplay at all.
The game has to be run with the correct options to allow an exact refresh rate match of the game to the card:
mame <game> –video ddraw -switchres –nohwstretch –nothrottle –triplebuffer –nomultithreading
cools
  • Last login:August 19, 2025, 04:19:37 pm
  • Arcade Otaku Sysadmin
    • Arcade Otaku
« Reply #6 on: June 19, 2015, 06:01:12 am »
Yes. For bonus points, mod the BIOS using ATOM-15.
