Author Topic: Recommended GroovyMame Setup  (Read 1961 times)
darryldale
  • Last login:March 07, 2016, 12:54:14 pm
« on: June 11, 2015, 10:11:27 pm »
OK, so the machine I'm working with now has an older P4 using an AVGA3000 going through a JPAC.
It's all inside a MK cabinet and a Wells Gardner K7000 monitor.
Assuming that the cabinet / K7000 / jpac are going to stay but that I want to go with something faster / better what would people recommend as an ideal setup? From what I'm able to determine it is something along the lines of:
* Half decent speed computer
* Windows xp 64 bit
* crt_emudriver with supported ATI video card (open to suggestions on the video card)
From what I've been able to determine in my reading I may have some issues getting Hyperspin to run in this setup?
I'm assuming that the ATI card will still plug into the J-Pac?
kortina
  • Last login:March 15, 2019, 05:06:26 am
Re: Recommended GroovyMame Setup
« Reply #1 on: June 12, 2015, 12:56:20 am »
Hyperspin is a resource hog.
There is a beta version of Hyperspin (1.4-Beta15) that is available to Platinum members... Apparently it is more efficient (cant confirm yet).
I run the older Hyperspin (1.3) on a Core2Duo (E8400). Running at 1024x768@60Hz full screen (31Khz).
I need to turn down some features to get everything running smooth, but it still looks fantastic.
Planning to upgrade to a real arcade monitor, and likely run at 640x480i (15Khz)
I would grab an ATi HD 4350 (lower 4xxx series), one that is passively cooled. (no noise, less stuff to break). Flash ATOM-15 on it, so that you get to see the entire boot sequence and not rely on the safety features of the JPAC.
I think that you need to avoid really new UEFI based systems, as the ATOM-15 probably wont play nice.
I would see what sort of Core2Duo you can find second hand (high clock speed, lower cores)
or go for a slightly older i5 or i7 setup (without UEFI if you can find it).
Also you might find it easier to use Win7 x64 these days. Most apps have been updated.
