Author Topic: Help Compliling Grooveymame with RacerMame  (Read 3385 times)
ArcadeBliss
  • Last login:October 09, 2025, 12:29:59 pm
« on: June 10, 2015, 01:01:55 am »
Hi,
I am trying to compile Grooveymame 0.160 and I am running into problems. I have downloaded the mame 0.160 source, applied hi_160.diff and then 0160_groovymame_015g.diff. After applying 0160_groovymame_015g.diff I receive these errors:
Code: [Select]
patching file src/osd/windows/video.c
patching file src/osd/windows/window.c
Hunk #7 FAILED at 786.
1 out of 7 hunks FAILED -- saving rejects to file src/osd/windows/window.c.rej
missing header for unified diff at line 5622 of patch
can't find file to patch at input line 5622
Perhaps you used the wrong -p or --strip option?
The text leading up to this was:
| //  winwindow_video_window_update
File to patch:
Skip this patch? [y]
Skipping patch.
10 out of 10 hunks ignored
patching file src/osd/windows/window.h
patching file src/osd/windows/windows.mak
patching file src/osd/windows/winmain.c
patching file src/osd/windows/winmain.h
Finished!
I am using Mame Compiler 64 v.2.0.162 with the current build tools. Can someone help me to successfully compile this version of groovemame? Thanks!
Calamity
  • Moderator
  • Last login:April 08, 2026, 02:30:14 am
  • Quote me with care
Re: Help Compliling Grooveymame with RacerMame
« Reply #1 on: June 11, 2015, 11:56:10 am »
Why aren't you using the new diffs and source (0.162)? Which hi_score diff are you using, the one from my site or from MKChamp's?
Steps to create a log:
ArcadeBliss
« Reply #2 on: June 11, 2015, 12:18:00 pm »
I know this is going to sound stupid but I have version 160 right now including all of the ROM sets that are necessary for it and I just want to make sure I have a test bed that I can use that's why I chose. The hi and grooveymame diffs are from your site.
Sent from my Nexus 5 using Tapatalk
Calamity
  • Moderator
« Reply #3 on: June 11, 2015, 12:49:30 pm »
Recent versions diffs are problematic because the new tools suck with line endings. The diffs for v0.162 are safe have been fully tested regarding this. Your romset should work for 99.99% of everything.
ArcadeBliss
« Reply #4 on: June 11, 2015, 03:15:24 pm »
Alright alright. I I'll update to 0162 and give it a try
Edit: so compiling 0.162 worked without a problem. Now I am dealing with with two patch errors from my racermame diff.
I will try to manually change the files by hand.
« Last Edit: June 16, 2015, 02:27:55 am by ArcadeBliss »
ArcadeBliss
« Reply #5 on: June 15, 2015, 05:21:59 pm »
So I created a patch just for racermame that builds upon the hiscore and grooveymame 162 patch. I am compiling it now and will do some testing tomorrow.
xga
  • Last login:September 24, 2024, 09:01:04 am
« Reply #6 on: June 15, 2015, 09:31:15 pm »
Awesome work, ArcadeBliss!  :applaud:
Keep us posted!
ArcadeBliss
« Reply #7 on: June 16, 2015, 12:25:31 pm »
So everything is working. I am in contact with the original author regarding publishing the new diff. If he allows it, I will post it here for human comsumption  :afro:
Calamity
  • Moderator
« Reply #8 on: June 17, 2015, 04:27:37 pm »
Great news ArcadeBliss, I wish you can make this available.
ArcadeBliss
« Reply #9 on: June 17, 2015, 06:12:10 pm »
I am still waiting on his feedback.
ArcadeBliss
« Reply #10 on: June 19, 2015, 02:10:24 am »
So I finished the compile and received the ok that I can distribute this diff. In the video options slider of mame, you can select the CShifter to show an alternate virtual shifter onscreen. When using the CShifter video option, the artwork files will need to be placed in your mame artwork folder.
Cheers.
Calamity
  • Moderator
« Reply #11 on: June 19, 2015, 04:39:38 pm »
This is great, thanks!
