Author Topic: Problem with Hack of Steering Wheel  (Read 7910 times)
kanario40
  • Last login:August 28, 2025, 06:53:00 pm
« on: June 07, 2015, 12:16:42 pm »
Does anyone know why happen in my hack of Steering wheel?:
https://www.youtube.com/watch?v=0xoXvNytdVo&feature=youtu.be
I have working perfectly the hack of Steering wheel using a L2M2 board but today I have tested and doens,t work does it,s see in the video.
Will be problem any component of L2M2 board is damaged or will be why the motor of steering wheel has let to works?
What do you think?
SailorSat
  • Last login:June 02, 2026, 10:13:38 am
    • For Amusement Only e.V.
Re: Problem with Hack of Steering Wheel
« Reply #1 on: June 08, 2015, 03:40:49 am »
So the motor is only turning right...
Check the lights of the L2M2 - do the direction leds light up correctly?
If they to, your transistor for turning left might be bad (or that IC in front of it)
If NOT, either your Logitech Wheel does not send a correct signal (which would be rather bad), or you got a problem on your l2m2 input circuit
I do all that stuff even without a Joystick ;)
Soft-15kHz, cabMAME, For Amusement Only e.V.
kanario40
« Reply #2 on: June 08, 2015, 08:17:13 am »
Hi SailorSat thanks by reply me.
Today I have tested the L2M2 board and when I switch on the pc at the beginning the leds of CCW appears switch on but then it switchs off.
Then I turn to the left the steering wheel and sound the noise the motor and works fine, but if I turn the steering wheel to the right,it switch on the led of CCW but no sound the motor.
Do you know now how can I solve it ?
SailorSat
« Reply #3 on: June 08, 2015, 09:04:28 am »
So the L2M2 input (and the logitech) seem work fine.
A simple way would be to check the AC outputs of the L2M2 and the motor.
If you are scared of voltages, you might check the motor first - unplug the 3 ac wires and check them with a multimeter.
you should be able to measure from the "neutral" to the two live (CW/CCW) pins, but not between the two live pins itself.
If you cannot measure anything from neutral to one of the two live pins, you may have a broken motor.
If both measure fine, most likely there is something wrong on your l2m2 outputs.
kanario40
« Reply #4 on: June 08, 2015, 10:43:15 am »
To check the motor you refer to go these steps?
1º-I put the scale of Muiltimetro to 200 V in AC:
2º-Then I connect first the tester black tip to the wire neutral blue and the tester red tip to purple wire of CCW:
3º-After I connect first the tester black tip to the wire neutral blue and the tester red tip to brown wire of CW:
And has to give any measure in each measurement if not will be broken the motor of steering wheel
Is it correct like have I explained?
SailorSat
« Reply #5 on: June 08, 2015, 12:01:55 pm »
that should work, but use the ohm meter of your multimeter. - i don't know what values to expect though :)
do NOT power on like that.
kanario40
« Reply #6 on: June 08, 2015, 05:00:37 pm »
In the brown wire there is 103V and in the purple wire nothing.
I go to change the triac U6,because can be that it,s damaged that triac.
What do you think?
SailorSat
« Reply #7 on: June 09, 2015, 05:23:05 am »
So Blue -> Purple reads nothing? Hm... That doesn't look good.
kanario40
« Reply #8 on: June 09, 2015, 05:45:42 am »
Today I have changed the triac U6 and nothing.
The led CCW at the begining is switch on in the board when switch on the pc.
After it switch off when I turn the steering wheel a bit.
What I can do more to solve the issue?
kanario40
« Reply #9 on: June 09, 2015, 09:51:18 am »
I have tested changing the purple wire of CCW by the brown wire of CW and now works fine when I turn to the right but not when I turn to the left.
I go to last measure take the voltaje of CWW to Fase wire of the motor and CW to Fase wire of the motor,to know if gives any voltaje if not will be the motor damaged.
« Last Edit: June 09, 2015, 09:52:51 am by kanario40 »
SailorSat
« Reply #10 on: June 09, 2015, 10:31:29 am »
First - disconnect your L2M2. from the motor.
try connecting the neutral (blue) and the purple wire without the l2m2, then switch on your setup. the motor should start running for as long as it gets power.
if it does, power off everything again, change the purple with the brown wire and switch back on - the motor should run in the other direction.
if it does run in both directions this way, your motor is fine
keep the motor disconnected from the L2M2.
if you turn your wheel RIGHT, the CCW led should light up (trying to turn the wheel left).
now turn your wheel LEFT, the CW led should light up (trying to turn the wheel right).
kanario40
« Reply #11 on: June 09, 2015, 11:07:14 am »
I have tested like you said me and does the next:
-When I connect the blue wire to brown wire works all the time the motor.
-When I connect the blue wire to purple wire doens,t work the motor
In both cases the orange leds of L2M2 works fine when I turn to the right and to the left.
Then the motor is broken?
SailorSat
« Reply #12 on: June 09, 2015, 01:38:23 pm »
I think so.
kanario40
« Reply #13 on: June 09, 2015, 02:23:10 pm »
If I unmount the motor can you solve it or it,s very hard do it?
Also I have a complete Panel SEGA Model 1 of a Virtua Racing.
Can I change the motor of Sega Model 1 and put it in the Daytona steering wheel or it,s different that motor?
kanario40
« Reply #14 on: June 10, 2015, 04:38:19 am »
The motor that has it,s this a Panasonic:
Does anyone what type of motor is that panasonic ?
« Last Edit: June 10, 2015, 05:05:55 am by kanario40 »
kanario40
« Reply #15 on: June 10, 2015, 12:42:31 pm »
Does anyone know where I can find a motor of Panasonic M9RC60SP4L10,100V 50-60Hz 25uF or any other motor compatible with it?
  • Moderator
« Reply #16 on: June 10, 2015, 03:49:28 pm »
Where are you located?
Some of us have spare parts laying around....
kanario40
« Reply #17 on: June 10, 2015, 04:00:51 pm »
Badmouth I live in Bilbao near of Guggenheim Museum in Spain.
kanario40
« Reply #18 on: June 11, 2015, 04:23:12 pm »
At the end I have solved the issue.It was in the condenser, it was damaged.I have changed by other and now works perfectly:
« Last Edit: June 12, 2015, 03:50:22 am by kanario40 »
  • Moderator
« Reply #19 on: June 11, 2015, 04:54:30 pm »
kanario40
« Reply #20 on: June 13, 2015, 05:03:11 am »
One more thing I turn the Steering Wheel with the switch off cabinet it sounds a noise a bit strong,maybe I need tense the belt.
Does anyone know how do tense the belt in that steering wheel?
kanario40
« Reply #21 on: July 14, 2015, 09:54:59 am »
I need buy a rubber dumper for the brake pedal because it,s broken,Do you know where can I get one?
  • Last login:June 13, 2026, 12:57:55 pm
« Reply #22 on: July 14, 2015, 12:44:42 pm »
You might be able to find one at a hardware store, in the hardware section in the "misc" drawer.  You'd have to bring the other parts with you to make sure it fits.
kanario40
« Reply #23 on: July 14, 2015, 04:04:41 pm »
Thanks Howard but at the end I have used a corrugated tube like this:
And then I wrapped with electrical tape and works perfect and cheap  :applaud:
« Last Edit: July 14, 2015, 04:06:15 pm by kanario40 »
