Author Topic: AMI Rowe 45 CD Combo PS/CCC problems  (Read 2624 times)
AceDKB
  • Newbie
  • Last login:May 14, 2015, 09:22:46 am
« on: May 14, 2015, 09:22:46 am »
Hello, I am new to juke boxes.  I have one that was working.  Then someone touched a wire to the CCC and now the display doesn't work and it wont play anything.  I looked inside and saw on the PS that the light next to the 8 is not on and on the CCC there are no lights on at all.  From what I have seen on line it may be a blown fuse on the CCC.  Can anyone help?
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
Re: AMI Rowe 45 CD Combo PS/CCC problems
« Reply #1 on: May 15, 2015, 06:26:39 am »
Hello AceDKB,
Welcome to the forum.
The PSU does not have fuses it has circuit breakers/trips. if you press these down and the 8 volt DC led comes on then all should be well. It on resetting the trips the 8 volt led is still out you will have damaged the power supply and it will need a repair.
Regards
Alan
Alan Hood
ami-man
UK
