Author Topic: Wells wmg2574 shuts down after it is on.  (Read 2120 times)
Shaker73
  • Last login:June 07, 2015, 10:59:27 pm
« on: May 11, 2015, 03:00:08 pm »
I have a wells wgm2574 monitor that shuts down after it is on for about 5 minutes. Turn it off and back on and it comes right back on. Any suggestions?
epicfatigue
  • Last login:May 15, 2016, 08:16:08 pm
    • http://www.retromods.com.au
Re: Wells wmg2574 shuts down after it is on.
« Reply #1 on: May 12, 2015, 05:59:35 am »
check the b+  with an analogue multimeter and see if you get a spike leading up and to shudown also record the voltage.
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #2 on: May 13, 2015, 07:48:35 pm »
IF this is the correct schematic :
https://www.wellsgardner.com/pdf/Schematics/K7400_25_inch.pdf
check R104 (10K/7W)   on SMPS primary.   must be <12K
R120 on the secondary side is also tolerance sensitive
68K/2W    use a 3 Watt when replacing
Shaker73
« Reply #3 on: May 21, 2015, 05:48:00 pm »
R104 is at 9.73K and R120 is at 67.8K. B+ went up to 300volts when it shutdown. It stayed at 160v after that.
qrz
« Reply #4 on: May 23, 2015, 08:34:42 pm »
ok.
the resistors are within 3% of spec .
may be an issue in the feedback circuitry.
check the following diodes
D105, 107 - 113, 117
also check R108, C126.
although not a common failure, check C105.
replace C713 and C730
SHOULD have gone into shutdown before ever reaching 300v !
while in it , suggest replacing the following capacitors as well
C107,115,126,310,502,610,613,615,706,709,716,805 and 806
