Author Topic: Great little $10 amp  (Read 3892 times)
  • Last login:Today at 10:41:43 am
« on: May 03, 2015, 02:53:08 pm »
I bought this on Amazon for a gift bartop, thought it'd share it. You can tap directly into your PC power supply, so no external adapter is necessary. No soldering required. I even bought a second one to have on hand.
http://www.amazon.com/DROK-Digital-Motorcycle-Amplifier-Dual-Channel/dp/B00C4MT274/ref=sr_1_1?s=electronics&ie=UTF8&qid=1430678932&sr=1-1&keywords=DROK®+Small+Digital+Audio+Motorcycle+Stereo+Amplifier+Ampli+Kit+15W%2B15W+Dual-Channel+Power+Amp+12+Volt
Slippyblade
Re: Great little $10 amp
« Reply #1 on: May 03, 2015, 04:22:06 pm »
« Reply #2 on: May 03, 2015, 04:44:17 pm »
Somebody mentioned this one a while back that I bookmarked.
Probably me.
Those are good too, BUT it doesn't come with the power adapter. I like the one I posted because you save space by not needing another outlet in the Bartop for a wall wart you have to pay extra for. Splice it into the 12v and Bob's your uncle.
« Reply #3 on: May 03, 2015, 09:42:16 pm »
If you're in Canada, I carry a similar model in the arcade shop: http://www.gameroomdesigns.ca/shop/mini-amplifiers/mini-2-channel-amplifier/
« Reply #4 on: May 03, 2015, 09:45:05 pm »
Does yours come with the power supply?
« Reply #5 on: May 03, 2015, 09:47:29 pm »
My current stock does, yes. I ordered them separately, however, and need to find a firm supplier.
« Reply #6 on: May 03, 2015, 10:16:48 pm »
Good for you. You might want to mention that on your page.  :cheers:
« Reply #7 on: May 03, 2015, 11:30:34 pm »
Here's a good comparison photo. Both are good, but the first one is great if you are tight on space.
« Reply #8 on: May 04, 2015, 06:20:37 am »
I checked with my supplier, and will also offer this smaller amplifier circuit. It will have the same quick-connects for no-solder functionality, and will be $10. (All I need is a good picture, but I'll add it into my online store today.)
Edit: Product added!
« Last Edit: May 04, 2015, 07:31:35 am by Rick »
« Reply #9 on: May 04, 2015, 07:44:25 am »
Just a quick note as well - some of these amplifiers (as with a number of the ones I carry - it depends on the stock my supplier has at the time) do come with quick-connects instead of a power jack in, so you can connect them the same way through splicing into the 12V from the power supply.
« Last Edit: May 04, 2015, 07:47:00 am by Rick »
