Author Topic: X-Arcade PCB Question--5v Line Coming Off the Board?  (Read 1163 times)
Venderhain
  • Last login:April 28, 2015, 08:33:12 pm
« on: April 27, 2015, 02:44:12 pm »
I'm building a stickless arcade stick using an X-Arcade PCB. I have an SOCD Cleaner that I need to wire between the buttons and the PCB, but the cleaner needs to be connected to a 5v line. Currently, X-Arcade's support is down because they are moving to a new office.  I'm wondering if any of you know where there is a 5v line/wire coming off of the X-Arcade PCB that I could splice?
Thank you.
05SRT4
  • Check out my Pow Pow
Re: X-Arcade PCB Question--5v Line Coming Off the Board?
« Reply #1 on: April 27, 2015, 08:26:33 pm »
I wasn't able to find much from an online search. You may need to wait or just bust out the ole multi meter and start poking around.
jeremymtc
  • Last login:May 19, 2026, 04:35:02 pm
« Reply #2 on: April 28, 2015, 12:07:57 am »
It looks like a couple of pins on socket J1 may be +5V/Ground... assuming that the X-Arcade's LED is 5V.
Venderhain
« Reply #3 on: April 28, 2015, 08:33:12 pm »
Hmm. Thanks. That seems plausible.
