Author Topic: Ultimarc U-Trak and SpinTrak help connecting to U-HID Nano  (Read 1470 times)
studi27
  • Last login:July 09, 2015, 02:43:57 pm
« on: April 24, 2015, 04:37:48 am »
Hi all - hoping someone can point me in the right direction. I have the above from Ultimarc, and I didn't buy the USB versions - I am now trying to connect them to U-HID Nano to give me the USB connections i need. However i don't know which pins to connect to on the U-HID. Can someone help? And also do i need to add a ground pin for these too?
Thanks in advance!
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
Re: Ultimarc U-Trak and SpinTrak help connecting to U-HID Nano
« Reply #1 on: April 24, 2015, 07:14:49 am »
We could have supplied the USB interfaces for these devices as an upgrade.
They can be connected to the U-HID but the connectors would need to be reworked. The two signal pins on a U-HID are opposite each other rather than being next to each other. You would need to use the U-Config program to set up three optical axes, and 2 5 volt pins.
You would need to splice together the grounds. Its not totally straightforward.
studi27
« Reply #2 on: April 24, 2015, 08:38:22 am »
Thanks for coming back to me Andy.
I have now managed to relocate my IPAC Ultimate so that i can connect the U-Trak directly to the board, so would just need a upgrade for USB for the SpinTrak. Can you PM me the link to this product in your store so i can order along with a few other pieces I need pls?
thanks again for your help.
studi27
« Reply #3 on: April 26, 2015, 03:36:30 am »
Thanks again Andy. Correct products now ordered and looking forward to finishing my panel!
