Author Topic: NEWBIE HELP with ROWE AMI Jukebox Orange w/Black Stripe wire for amp mute  (Read 2506 times)
Cheyenneguy
  • Last login:April 24, 2015, 12:46:15 am
Hello All,
Newbie here to site...  I have a Rowe AMI jukebox with the jump conversion kit using the Rowelink Controller 40955703 and the orange w/black strip wire is connected to the "mute amp".
lilshawn quoted... back in 2012, see below...  My question is... Do you simply ground this orange w/black wire to the ground point close to the top of the box to keep the amp working at all times from the audio input player?
Thank you all, I like this site, very informative.
Re: Advice on Rowe Ami jukeboxes
« Reply #218 on: November 11, 2012, 07:23:33 pm »
okay, it's basically like this
the orange w/black stripe wire runs from the computer to the amp (makes a stop at the light controller...irrespective.)
basically when the computer wants the cd player to play music through the amp, the computer grounds out (connects to ground) the orange w/black stripe wire and the amp "un-mutes" and allows anything playing through the audio input to play
when the song is done, the computer disconnects that wire from ground and the amp (is supposed to) mute again.
« Last Edit: April 23, 2015, 11:22:27 pm by Cheyenneguy »
