Author Topic: Rowe R-92 Amp Sound on Startup  (Read 1753 times)
Fredro
  • Last login:April 29, 2015, 11:30:54 am
  • Owner of a Rowe R-92
« on: April 23, 2015, 11:05:40 am »
Hi all - When a records starts on the R-92, for the first few seconds, the sound is noticeably louder and distorted. After that, it calms back down and sounds good. It's almost like there's a power overage that needs draining away before the amp sounds normal.
Any Thoughts?
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
Re: Rowe R-92 Amp Sound on Startup
« Reply #1 on: April 24, 2015, 06:32:46 am »
Hello Fredo,
What amplifier model number is fitted to your R-92? is the mute plug fitted? have you checked for dry joints (cold joints USA) on the connections pins connecting the pre-amplifier to the output stages and the 13 pin jumper plug?
Regards
Alan
Alan Hood
ami-man
UK
