Author Topic: Mounting Golden Tee TB  (Read 1625 times)
Metimbo
  • Last login:June 15, 2010, 02:52:32 pm
  • A stretched mind will never be the same again.
    • Metimbo's Website
« on: December 26, 2003, 05:32:22 pm »
Ok.  Got my Golden Tee TB in from Happs.  I am cutting my cp tonight and I dont see how this thing is supposed to mount.
Do I buy the mounting plate from Happs here?
http://www.happcontrols.com/trackballs/55110100.htm
I think that's it.  But, I want to go ahead and cut my CP tonight.
If so, then I should just cut out this hole for the 3" TB at the bottom as seen here?
http://www.happcontrols.com/trackballs/55110100m.htm
Thanks,
~Tim
RacerX
  • Last login:April 25, 2024, 04:53:33 pm
  • Longtime member, sometime poster.
Re:Mounting Golden Tee TB
« Reply #1 on: December 26, 2003, 05:37:18 pm »
I used their mounting kit to mount my 3" ball.  But other folks here have mounted theirs directly to their control panel.
I like the mounting kit because I didn't think I could cut a perfectly circular hole in my CP.  I just cut a square and used the mounting plate.
But it's really whatever you prefer.
Metimbo
    • Metimbo's Website
« Reply #2 on: December 26, 2003, 05:44:44 pm »
Let's say I do use the mounting plate.  Do I just cut a square in the CP according to the link above?
Thanks again,
~Tim
TalkingOctopus
    • My Arcade
« Reply #3 on: December 26, 2003, 09:01:28 pm »
Yep that's it.  I just cut a 5.5 " x 5.5" square for mine.
Metimbo
    • Metimbo's Website
« Reply #4 on: December 29, 2003, 12:23:30 pm »
Thanks for your reply's.  I ordered my mounting kit today.
How do you go about drilling the 3" hole for the TB in the Lexan?
Also, does anyone have a picture of what I'll need to get from HomeDepot for attaching Lexan to the CP?  I think they are called Carriage Bolts?
~Tim
NoOne=NBA=
« Reply #5 on: December 29, 2003, 01:24:50 pm »
TalkingOctopus
    • My Arcade
« Reply #6 on: December 29, 2003, 02:39:25 pm »
I used a 3 inch hole saw.
RacerX
« Reply #7 on: December 29, 2003, 04:17:26 pm »
I didn't.  The mounting plate has the hole in it already.  So I just cut a square as I did in the control panel.
