Author Topic: Some questions about making a power button  (Read 1694 times)
Shieldwolf
  • Last login:November 16, 2020, 12:48:53 am
  • SpearShield.com
« on: December 25, 2003, 06:53:48 pm »
 I don't have a computer case so I need some help making a power button.
1.What do I need to make it?
2. Any tricks to wiring it?
Any help or diagrams would be great.
Merry Christmas all.
Shieldwolf
SpamMe
  • Last login:July 01, 2006, 03:19:58 am
  • .creature of bad habit.
    • Mame cabinet blog
Re:Some questions about making a power button
« Reply #1 on: December 25, 2003, 07:53:49 pm »
Your motherboard should have 2 pins (check your user manual) that, when connected, turn on your PC (at least that's what I'm assuming you're trying to do). A computer case's power button is just a momentary switch. Its normally-open prong connects to one of the pins, and it's ground to the other. When the button's pushed, puter comes on. An arcade microswitch is well suited to this sort of thing, and is connected the same way. :)
Generic Eric
« Reply #2 on: December 25, 2003, 09:00:14 pm »
There was a thread recently called "one button to start them all..."  or something like that.  you should find an answer there.
edit
Found it.  Go here  It was on page two.  It should either answer your questions, or give you new ones.
/edit
« Last Edit: December 25, 2003, 09:10:06 pm by generic_eric »
Shieldwolf
  • SpearShield.com
« Reply #3 on: December 26, 2003, 04:23:51 pm »
I checked out the link. That wasn't as informative as I was looking for. Any other advice?
TalkingOctopus
    • My Arcade
« Reply #4 on: December 26, 2003, 09:00:22 pm »
It is really just like hooking up any other arcade button.  He covers everything you need to know above.  There will be 2 wires that connect to from your power button to your motherboard.  Simply clip the wires and attach them to an arcade button.
