Author Topic: .  (Read 3347 times)
ChanceKJ
« on: March 26, 2015, 02:46:56 am »
« Last Edit: March 19, 2021, 12:17:07 am by ChanceKJ »
grantspain
Re: Getting frustrated with my 19" WG 7700
« Reply #1 on: March 26, 2015, 03:36:53 am »
so you have no blue but the chassis functions ok?
ChanceKJ
« Reply #2 on: March 26, 2015, 12:56:23 pm »
« Last Edit: March 19, 2021, 12:17:14 am by ChanceKJ »
« Reply #3 on: March 26, 2015, 01:00:18 pm »
arcadecup.com
  • Last login:May 19, 2026, 11:21:47 am
« Reply #4 on: March 26, 2015, 01:04:53 pm »
Just upgrade that ---maternal-smurf--- to a 27" Asus G-Force 4K LightWave Super-Dimensional LCD and be done with it.
Or Arcadecup.com. If it can be fixed, he can fix it.
ChanceKJ
« Reply #5 on: March 26, 2015, 01:11:01 pm »
« Last Edit: March 19, 2021, 12:17:18 am by ChanceKJ »
« Reply #6 on: March 26, 2015, 01:14:58 pm »
Quite honestly, there are now probably a single handful of guys here at BYOAC that could help with anything more advanced than a cap kit, since most builders now are keen on LCDs, slim cabs, and Widescreen HDMI TVs and know nothing about arcade CRTs.
Send a PM directly to Buffett on KLOV. He can probably help.
Edit: Buffett is a member here, too. Send him a PM. Maybe he can post the answer here as well.
« Last Edit: March 26, 2015, 01:16:31 pm by yotsuya »
grantspain
« Reply #7 on: March 27, 2015, 06:37:32 pm »
yeah  ignore anything i say
« Reply #8 on: March 27, 2015, 07:43:21 pm »
No offense intended, Grant. You're certainly one of the two or three people here that knows how to fix these things.
« Last Edit: March 27, 2015, 07:45:18 pm by yotsuya »
grantspain
« Reply #9 on: March 27, 2015, 07:53:09 pm »
well i have been repairing coin op since 86 and i run a company called error 24 in the u.k so i should know what i am talking about,fixed my first machine aged 10-it was a centipede
what i was getting at is the component is on the blue circuit so isolate the blue gun by desoldering the pin of the crt socket,then see what happens
mgb
  • Last login:June 05, 2026, 10:45:08 pm
  • North East, US
« Reply #10 on: March 28, 2015, 10:37:49 am »
Just some thoughts, you are using the schematic while troubleshooting, right?
There are some voltages listed on there that may help to narrow down.
Like Grant says, these components (c804, r811) are in the blue circuit.
Grants advice on removing the blue gun from the circuit of course makes sense.
I wonder also beside that, would it be beneficial to remove q801 from the circuit, as it is the first point of the blue circuit after out1 of the ic
ChanceKJ
« Reply #11 on: March 29, 2015, 05:49:53 pm »
« Last Edit: March 19, 2021, 12:17:24 am by ChanceKJ »
