Author Topic: Possible Solution for DIY Star Wars Yoke?  (Read 5733 times)
rbarr110
  • Last login:January 28, 2026, 12:10:10 pm
  • I already built my own arcade controls!
« on: March 12, 2015, 02:25:05 pm »
I haven't been here for a long time, but when I was here and in my absence, I have always been trying to figure out a decent DIY Star Wars yoke.
I happened to come across this, and thought it may work if mounted in a DIY yoke housing.  I have some ideas on how to do it, but wanted thoughts/opinions about the controller itself before putting my CNC to work and buying the parts.
http://www.instructables.com/id/USB-Game-Pad-With-Tilt-accelerometer-Mouse/?ALLSTEPS
Generic Eric
Re: Possible Solution for DIY Star Wars Yoke?
« Reply #1 on: March 12, 2015, 02:38:07 pm »
lamprey
« Reply #2 on: March 12, 2015, 02:38:20 pm »
I think there are many better options than a accelerometer for this application. If it were me I'd using something analog(ish) like a U360 or something similar. I was doing some research for a mini-cabinet and found these guys:
https://www.sparkfun.com/products/9032
They have potentiometers in them so, in theory, they'd act like a real yoke. I could easily conceive of a way to use this type of joystick with a yoke to achieve similar results to that of a real yoke.
lamprey
« Reply #3 on: March 12, 2015, 02:40:50 pm »
Another option is to get 2 5k pots and minic a real yoke and might even be the easiest option.  :dunno
rbarr110
« Reply #4 on: March 12, 2015, 02:50:10 pm »
I thought about that, gave it a go years ago, and ended up with gear problems.
rbarr110
« Reply #5 on: March 12, 2015, 02:53:04 pm »
You need to get on that KADE hype train!
http://forum.arcadecontrols.com/index.php/topic,134781.msg1390657.html#msg1390657
I dont see how this works for X-Y axis motion, great for regular gamepad/cp controls, but the addition of an accelerometer is what may work for Star Wars Yoke.  Can an accelerometer be added to the KADE?
rbarr110
« Reply #6 on: March 12, 2015, 02:54:37 pm »
I don't want to use a thumbstick to play Star Wars, I want to recreate the look and feel of the Flight Yoke without dropping $600 for a reproduction yoke.
I don't think my initial post clearly states what I am thinking.  Using the keyboard/mouse encoder in the gamepad project with the accelermoter mounted in a yoke like housing to mimic the original controller movement.  I am not intending on using the cheesy SNES USB controller itself.
« Last Edit: March 12, 2015, 02:59:19 pm by rbarr110 »
Generic Eric
« Reply #7 on: March 12, 2015, 03:15:57 pm »
In that link is a post of the 2 pots connected to the stick.  But if you are against using gears.  I don't think this is a solution for you.  I don't have a reply regarding the accelerometer.
I will follow your Star Wars Yoke project with interest .
  • Last login:Today at 09:55:04 pm
« Reply #8 on: March 12, 2015, 03:32:22 pm »
KADESTICK is an analog joystick encoder.
Electrically it is the same as any other analog encoder/SW yoke adapter, providing absolute X/Y values rather than relative position changes like a mouse/accelerometer.
You can use an Atari yoke from Firefox or several other games (there's a list somewhere around here IIRC) -- you might be able to find a yoke from that list for sale on KLOV.
I don't think the KADE team is planning on including an accelerometer in any of their encoders in the forseeable future.   :dunno
lamprey
« Reply #9 on: March 12, 2015, 03:36:02 pm »
I wouldn't use the thumb stick as it is. Rather, I'd put it in a controller and use the thumb stick as a means to mimic the pots on a real controller. If I ever get around to making a mini-yoke I'll post info on it.
Honestly, if you want to mimic the real thing, I'd try to get a used yoke from star wars or other machine. They can be had for a reasonable amount of money and you won't have to sacrifice too much.
« Last Edit: March 12, 2015, 03:42:21 pm by lamprey »
rbarr110
« Reply #10 on: March 13, 2015, 01:41:27 pm »
I havent seen a used star wars yoke on sale for a while, granted I havently actively been looking in the last year or so, but they were rarely under $350.  I have seen some refurbs and/or reproduction yokes for about $600 recently.
The parts for the encoder and accelerometer are $30.  Worth a shot for that price, I have alot of the other parts laying around that would be needed to make an attempt at a yoke.  So very little expense for an experiment at this time.  Will give it a go I think, it will probably take me a few months to actually do anything.  Always lots of projects I want to do, time is usually the problem.
ark_ader
  • I glow in the dark.
« Reply #11 on: March 13, 2015, 04:44:15 pm »
What about RAM Controls?   :duckhunt
