Author Topic: Betson Imperial / Kortek KT-2914 and Raspberry Pi  (Read 2459 times)
portwojc
  • Last login:July 19, 2015, 09:42:14 pm
« on: March 10, 2015, 10:23:42 pm »
Is it possible to have a Raspberry Pi work with a Betson Imperial / Kortek KT-2914 monitor?
I have a Raspberry Pi with powered HDMI to VGA adapter and a  GBS-8100 video converter (http://www.digitalsystemsdesign.co.uk/product_uploads/13153855771.pdf).  Hooking the VGA to the GBS card and then the output to the monitor doesn't show anything.  Going straight to the monitor I get the monitor complaining about the signal.
In the boot/config.txt I have tried
#hdmi_group=2
Along with
# 640x480   60Hz
hdmi_mode=4
or
# 800x600   60Hz
hdmi_mode=9
With no luck.  Any suggestions would be appreciated.
Thank you,
Jason
MonMotha
Re: Betson Imperial / Kortek KT-2914 and Raspberry Pi
« Reply #1 on: March 11, 2015, 01:45:21 am »
You should not need the downscaler/converter.  The monitor accepts 640x480 VGA and 800x600 SVGA directly.  I'd figure out why it claims out-of-range when you try to supply those.  Chances are the downscaler isn't going to be happy with whatever you're actually outputting, either.
portwojc
« Reply #2 on: March 11, 2015, 10:08:31 am »
So skip the conversion board as it won't be needed.
I did find this link, http://www.raspberrypi.org/forums/viewtopic.php?f=29&t=24679, the covers custom settings for the raspberry pi HDMI output.  That should help me work this out and give the signal the monitor wants.
Thank you.
Jason
