Author Topic: rowe ami r90 error 39 or 38  (Read 3763 times)
frankie M
  • Last login:March 31, 2015, 04:44:20 pm
« on: March 10, 2015, 06:06:26 pm »
Hi
I recently bought a R90. It did work bur has now stopped selecting. The turntable turns. I can make carousel turn with switches. i have metered out all connections ok. Power supply of and i think all motors are.
any help please?
Frankie M
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
Re: rowe ami r90 error 39 or 38
« Reply #1 on: March 11, 2015, 11:15:05 am »
Hello Frankie,
The two errors you quote both refer to issues with the inner cam switch, both of these error will shut the jukebox down until it has been turned off and back on again.
If you have just got this jukebox check for stupid things like the two smicro switches on the transfer motor (cam switches) these are fitted with un-insulated spades and if you have moved the mechanism out of the jukebox the ends of the spades could be shorting the switches out, so check to see that none of the connection are touching.
Check the mechanism connection pins for dry joints (cold joints USA).
Please let us know how you get on.
Regards
Alan
Alan Hood
ami-man
UK
frankie M
« Reply #2 on: March 12, 2015, 03:23:36 pm »
Hi Alan
Ive metered out the switches working fine. I metered out the pin from mech control board to main board ok (with loom attached). Any ideas?
Funny thing is it worked (but wrong selections x3) and then just packed up.
Cheers
Frankie
