Author Topic: Cables/Video Card I need for 27" Presentation Monitor (9 pin RGB or BNC?)  (Read 1584 times)
nipsmg
  • Last login:September 07, 2025, 07:37:55 pm
  • ROONEY!! ERRGH!!
    • Arcadia
I'm going today to pick up a 29" (27" viewable) presentation monitor.
Edit: Proton VM-290 27" Color monitor:
It's got BNC's and a 9 pin RGB on the back, along with AV in.
I'd like to drive this with BNC/RGB, as I heard it'll be the clearest picture.
My question is this:
A) Should I get an ArcadeVGA to do this?
B) Where can I get a cable for the BNC or the 9 pin RGB to interface with the ArcadeVGA card (or wahtever card I need)
Thanks in advance.
NipsMG
« Last Edit: December 23, 2003, 08:15:59 pm by nipsmg »
nipsmg
  • ROONEY!! ERRGH!!
    • Arcadia
Re:Cables/Video Card I need for 27" Presentation Monitor (9 pin RGB or BNC?)
« Reply #1 on: December 23, 2003, 08:22:14 pm »
I picked it up today.
Here's a link to the auction the guy had (fortunately for me, the bidder backed out).
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=2764576197
to sum it up, there's 3 inputs
One with ONE BNC and TWO RCA's for audio.
One with 3 RCA's.
and one 9 pin RGB input.
There's also a swtich that points to the RGB input to switch between positive/negative sync polarity.
It's a Proton VM-290.
What's the best plan of attack?
NipsMG
Also: If anyone has a datasheet on this monitor (i've been unable to find one), please let me know.. Thanks! :-D
« Last Edit: December 23, 2003, 08:23:23 pm by nipsmg »
RandyT
  • Last login:Today at 09:45:21 am
    • GroovyGameGear.com
« Reply #2 on: December 24, 2003, 12:04:04 am »
Ito sum it up, there's 3 inputs
One with 3 RCA's.
Probably looking at composite here.  Not what you want.
It doesn't say "TTL" on it anywhere does it?  If not, you are probably best off with an ArcadeVGA card and the pre-labeled cable.  Wire it to a DB-9 (grab a pinout off the web for a 9-pin VGA connector) and cross your fingers.  If the unit isn't multi-sync, you may have to live with some resolutions being unavailable, but this varies with different monitors.
RandyT
nipsmg
  • ROONEY!! ERRGH!!
    • Arcadia
« Reply #3 on: December 24, 2003, 06:36:26 am »
No it definitely doesn't say TTL anywhere.
I've been looking non stop for the past 2 days for any technical information on the VM-290, and have found NOTHING. :(
I've got some messages in on the forums for Ultimarc, but I figured this was what I was going to have to do anyways.
We'll see..
I'll tell you this tho.  I went to pick it up, the guy hooked a dreamcast to the composite connection, and the picture was BEAUTIFUL.. Can't WAIT to see the RGB connection on this monitor.
Now I just have to build the cabinet.... :-/ (Won't fit in my defender, unfortunately :-D)
--NipsMG
