Author Topic: Mamewah 1.62 "bad music file" music won't play  (Read 1556 times)
stevodevo
  • Last login:March 07, 2022, 11:27:18 am
« on: March 02, 2015, 08:19:02 am »
Posted this over in the MAMEWorld forums but have yet to receive any response... maybe someone here has seen this error message:
I'm running 1.62b12 and had to rebuild mamewah tonight... not sure what happened but I had to re-run the system setup.bat and register a dx8.0 dll in order for it to work again...
In any case, the only error I'm receiving now is "bad music file" and my background music isn't playing.
It was before I had to rebuild so I don't think it's the files themselves...
Which file in the system files controls music or is that just a directX sound file? I will try reinstalling directx 8.0 and see if that fixes it. Just surprised I couldn't find any other posts dealing with this error.
Since that post I have yet to try re-installing directx.  I'm running dx 9.0c so not really keen on downgrading.  Any suggestions for restoring what were working music files back to working again??
Thanks again!
Re: Mamewah 1.62 "bad music file" music won't play
« Reply #1 on: March 03, 2015, 12:35:17 pm »
Sounds / music are played by DirectX.
DirectX 9c should work ok as far as I know...I am using on at least one machine and sounds work. That said I do not use the music playing feature.
Is it an MP3 file? Does the file play OK in Media Player?
stevodevo
« Reply #2 on: March 06, 2015, 08:09:38 am »
Thanks Minwah... yes, the files worked up until *something* happened that caused me to have to rebuild... I'm thinking my son pulled the plug or somehow didn't power down the cab properly.
They are all mp3's.  I will try them through Media player at the next opportunity.  Sound works fine when launching the games, it's just the background music inside Mamewah itself that is now broken.
