Author Topic: Fixing Plexi to Control Panel  (Read 1874 times)
Pat Shaw
  • Last login:May 13, 2015, 07:12:42 pm
« on: February 19, 2015, 07:13:17 pm »
Hi All, So you have your control panel built with artwork fixed and your protective plexi ready to sit on top. How do you fix the plexi? Do you just rely on pressure from the buttons clamping it to the CP or do you use a glue?
bfauska
Re: Fixing Plexi to Control Panel
« Reply #1 on: February 19, 2015, 07:18:49 pm »
For home use I think most people use the buttons and the fact that the t-molding keeps the edges masked to hold it in place. In the wild most the ones I've seen have ugly screws through the plexi.
Pat Shaw
« Reply #2 on: February 19, 2015, 07:27:44 pm »
Yeah I want to avoid screws at all costs. It's the first time i've built one so just wanted to check that the pressure from the button screws alone would be enough.
Richardgregory
  • Last login:November 17, 2021, 01:15:10 pm
« Reply #3 on: February 19, 2015, 07:52:49 pm »
Buttons clamping the plexi works for me.....it's quite secure.
Well Fed Games
  • Delicious!
« Reply #4 on: February 19, 2015, 08:06:24 pm »
I've used carriage bolts which have a nicer appearance than screws.
DietCoke
  • Last login:October 10, 2020, 08:32:13 pm
« Reply #5 on: February 19, 2015, 08:28:12 pm »
This would have been a great post for me LAST SATURDAY.
ChanceKJ
« Reply #6 on: February 19, 2015, 09:42:51 pm »
I got this....
« Reply #7 on: February 19, 2015, 09:45:12 pm »
Yep. Carriage bolts are baller, bro.
liquid134
  • Last login:February 15, 2018, 07:58:20 pm
« Reply #8 on: February 19, 2015, 09:46:48 pm »
yea, most games have carriage bolts of some sort, some times screws or hex heads. very rarely youll see security square heads. carriage bolts look nice, but if its just for home use, and it wont be beat on or abused, button pressure should be plenty. just curious, how is your joystick mounted?
DietCoke
« Reply #9 on: February 19, 2015, 10:57:04 pm »
That's a pretty personal question there, mister.
AzureKnight
« Reply #10 on: February 20, 2015, 10:28:32 am »
I bought carriage bolts but held off on putting them in.  It turns out I don't even need them so far.  The buttons alone do a fine job of holding the plexi down for my build.
Todesengel
  • Last login:July 30, 2024, 09:42:08 pm
« Reply #11 on: February 20, 2015, 01:22:33 pm »
T-Molding and the Buttons is all I have holding it in place.
Pat Shaw
« Reply #12 on: February 22, 2015, 04:47:19 am »
Thanks for your advice guys. What thickness of Plexi would you suggest using?
AzureKnight
« Reply #13 on: February 23, 2015, 01:14:25 pm »
I'd have to check my order sheet, but I'm pretty sure I went 1/8" on mine.
aldub516
  • Last login:November 29, 2018, 03:32:46 pm
« Reply #14 on: February 23, 2015, 09:09:01 pm »
i used some carriage bolts as well in certain areas as my 1st cabinet had a big control panel so a lot of the edges were free to be lifted up. It might sound crazy, but i enjoy to look of nice clean carriage bolts if placed properly.. They give it kind of a heavy duty and professional look to it.
