Author Topic: Specs for I-Pac2 based control panel  (Read 1739 times)
someUserName
  • Last login:March 01, 2015, 10:39:08 pm
« on: February 16, 2015, 09:15:06 am »
I read through several posts and other documentation on the various controls for a cabinet and was wondering if the following combination of items would work. I was going to purchase the items through UltiMarc. I didn't want to buy more than what I needed, but I definitely didn't want to miss something and have to pay for more shipping...
I know the I-Pac2 has 32 inputs, so I should have 4 extra inputs for future expansion. Am I assuming that the trackball does not use any inputs since it goes through the USB?
1 - I-Pac2
2 - Mag-Stick Plus                           - 8 inputs
16 - buttons                                    - 16 inputs
2 - Pause/Esc buttons                     - 2 inputs
2 - 1 player / 2 player                       - 2 inputs
1 - U-Trak Pearl with USB2 + Cable  - 0 inputs?
  • Last login:Today at 05:35:38 am
Re: Specs for I-Pac2 based control panel
« Reply #1 on: February 16, 2015, 09:43:22 am »
Welcome aboard, SomeUserName.   ;D
You may want to add 2 inputs for Coin 1 and Coin 2.
DudeRegular
« Reply #2 on: February 16, 2015, 12:14:22 pm »
The 2015 version of the ipac2 now has the interface for spinner and trackball built in. It is via additional 2.54mm pins so you don't use up your digital inputs to also connect it. I just wired up one with an old golden tee trackball and it works great.
You are good on the amount of inputs. You can also use the ipac2 shift key feature to move the admin  functions to button combos rather than dedicated keys. This saves buttons, wiring, and inputs. I believe it is also more user friendly. You are certainly not near as heavy on admin keys as some, but it is something to keep in mind.
someUserName
« Reply #3 on: February 16, 2015, 08:52:04 pm »
Thanks for help!
This may be a stupid question, but with the trackball, would I need the "USB2 + Cable" option? I assume that I wouldn't since it can connect directly into the I-Pac2.
DudeRegular
« Reply #4 on: February 16, 2015, 09:09:01 pm »
You should be good with out the additional usb cable. Andy, the guy who runs ultimarc, answers emails pretty quickly if you want to confirm though. Also I guess I assumed you were ordering directly from ultimarc. Some other vendors may not have the new parts if not specifically advertised as such on their site.
paigeoliver
  • Awesome face!
« Reply #5 on: February 16, 2015, 09:19:34 pm »
You don't need 8 buttons per player. Nothing uses that but later consoles and those aren't really playable due to lack on analog controls and lack of logical shoulder buttons.
someUserName
« Reply #6 on: February 16, 2015, 09:20:35 pm »
Yup, you are correct; I will be ordering directly from Ultimarc.  I initially was going to email him directly, but thought I would try the forum first since he probably gets a lot emails. I'll email him and find out and update this post with the information.
Slippyblade
« Reply #7 on: February 16, 2015, 09:36:41 pm »
Andy from Ultimarc is on the forums, actually.  That's one of the things that makes this place cool.  Most of the reputable vendors are forum regulars!
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #8 on: February 18, 2015, 02:56:33 am »
Thanks for help!
No, if using the 2015 board you dont need the USB option as the trackball plugs directly into it.
Andy
someUserName
« Reply #9 on: February 18, 2015, 11:20:20 pm »
Awesome. Thanks Andy!
