Author Topic: <RESOLVED>IPac2 Problem  (Read 1639 times)
JimmyU
  • Last login:January 31, 2026, 05:24:44 pm
  • I believe I can fly!
« on: February 08, 2015, 03:12:25 pm »
I have an older PS/2 Ipac2 I bought a few years ago that I'm having a problem with. The IPac won't register any button presses and the LED on it remains lit. I'm using a PS/2 to USB adapter. I checked an older PS/2 keyboard I had laying around and that worked with the adapter. I also plugged the keyboard into the bypass of the IPac and its Num, Caps and Scroll lock LED's kept flashing. Any advice you guys might have would be greatly appreciated.
« Last Edit: April 04, 2015, 11:47:50 am by JimmyU »
Richardgregory
  • Last login:November 17, 2021, 01:15:10 pm
Re: IPac2 Problem
« Reply #1 on: February 08, 2015, 07:12:18 pm »
I wonder if the PS/2 to USB adapter needs to be an Active type and not a passthru.
adder
Re: IPac2 Problem
« Reply #2 on: February 08, 2015, 07:19:51 pm »
is this a recent problem or has it never worked for you.
no doubt you dont have the proper ultimarc ps2 to usb cable, im not sure u can get away with using an adapter instead.
Andy at Ultimarc could supply you with the proper ps2 to usb cable.
note: it's advised to use the one he supplies rather than getting one off eg. ebay.
JimmyU
Re: <RESOLVED>IPac2 Problem
« Reply #3 on: April 04, 2015, 11:51:17 am »
I was just using the wrong kind of adapter. This kind works:
This kind does not:
