Author Topic: Raspberry Pi questions, very technical  (Read 10510 times)
Sarver Systems
  • Last login:October 07, 2020, 12:46:05 am
« on: February 06, 2015, 02:44:06 pm »
A friend of mine at work is looking into getting one.
We were discussing what it is, how it works etc...
Then it dawned on me, and idea I have.
But, I know absolutely nothing about them, so here is where you come in.
Is there any that the Pi can be used as a board tester?
For example, connect the Pi, via the proper harness to an arcade board, and have it test all of the proper outputs (also via a harness) and display on the screen a list of proper readings along with actual readings.
Basically, I want to build a computer-controlled test system.
johnrt
Re: Raspberry Pi questions, very technical
« Reply #1 on: February 06, 2015, 03:21:26 pm »
No. I guess you're thinking about JAMMA boards. I don't see how you can use a Pi to test anything on a PCB.
« Reply #2 on: February 06, 2015, 03:26:51 pm »
Exactly. You want to test boards, build one of these like I did: http://forum.arcadecontrols.com/index.php/topic,121731.msg1291487.html#msg1291487
Sarver Systems
« Reply #3 on: February 06, 2015, 03:52:30 pm »
Yes and no.
I'm building a supergun with built-in display as we speak.
I want to test pinball boards, as well as Pac-Man, etc... boards.
I want to test down to component level.
« Reply #4 on: February 06, 2015, 04:00:49 pm »
Yes and no.
Here's the question to ask, then... How?
johnrt
« Reply #5 on: February 06, 2015, 04:01:20 pm »
You can't! For example: You need a logic tester for testing integrated circuits. That means you have to take the IC out of it's socket and insert it into the tester. In my opinion the Pi is NOT an alternative for doing even that.
WindDrake
  • Last login:December 03, 2020, 09:49:05 pm
  • Electrical Engineer
« Reply #6 on: February 06, 2015, 05:37:43 pm »
If it's got enough GPIO, and the GPIO is fast enough, you could do things Fluke 9010A style and simulate a CPU.
But holy ---steaming pile of meadow muffin--- is that complicated.
johnrt
« Reply #7 on: February 06, 2015, 05:54:08 pm »
Through the JAMMA harness... NO!  :lol
Generic Eric
« Reply #8 on: February 06, 2015, 06:01:22 pm »
null
« Last Edit: February 06, 2015, 08:55:03 pm by Generic Eric »
