Author Topic: CRT Arcade chassis in europe  (Read 3722 times)
kourampies
  • Last login:February 10, 2015, 06:54:55 pm
    • my homepage
« on: February 05, 2015, 06:50:44 pm »
I have 3 68cm tubes nowadays, but no working chassis for any of them. I ve been delaying this for years, but I want to finally get my cab done... I havent measured anything, because I dont have the space to bring the tubes here, and dismantle the donor TVs on the two, but if Im sure I can get a quality chassis that will work properly with 230v power etc, I will start.
Any suggestions?
grantspain
Re: CRT Arcade chassis in europe
« Reply #1 on: February 05, 2015, 07:00:09 pm »
you need to read the impedance of the deflection yoke,polo 2 chassis are readily available in europe and match standard crt
polo 2 are auto switching 15/25khz and also full range ac(90-250vac)
kourampies
    • my homepage
« Reply #2 on: February 05, 2015, 07:01:28 pm »
I even got the special inductance multimeter. One of the CRTs definitely should fit genetic chassis, since it had something like that already.
But where are they readily available?
grantspain
« Reply #3 on: February 06, 2015, 01:02:15 am »
kourampies
    • my homepage
« Reply #4 on: February 06, 2015, 02:17:43 am »
http://www.videotronicsuk.com/
if you want new chassis then you would need to buy from china
http://www.sanstargame.com/productsDetail.aspx?pcode=Chassis%201%2025%22-29%22
The ones on the UK site are refurbished? New caps etc? Which one do you suggest if we say all are compatible? (15khz, simple curved 68cm tubes)
grantspain
« Reply #5 on: February 06, 2015, 06:08:30 am »
best thing for you to do first is to post a photo of the deflection yoke connector on your tubes,then read the impedance of both the vertical and horizontal windings of the deflection yoke
do you intend to run 15khz only games?
apfelanni
  • Last login:February 18, 2019, 01:55:28 pm
« Reply #6 on: February 10, 2015, 02:43:49 pm »
wouldnt it be easier to grab a decent tv with a quality chassis , than trying to adapt some c grade arcade stuff made in china ? for 29 inch lowres i would recommend a philips of the 29pt5xxx series . should be available in greece .
kourampies
    • my homepage
« Reply #7 on: February 10, 2015, 04:45:13 pm »
I had absolutely no luck in 3 years of searching for a 68cm tv to buy. Note that Im not in athens. I have 2 faulty tvs with good tubes, and one arcade monitor. I was thinking of trying to find out whats the best tube, and fit the best chassis I can find on it.
grantspain
« Reply #8 on: February 10, 2015, 05:58:27 pm »
until recently there was Greek manufacturer of crt call gdtronics,they made multi sync,15khz,25khz and svga crt monitors
kourampies
    • my homepage
« Reply #9 on: February 10, 2015, 06:06:57 pm »
Never heard about them before. Their website is down... Are they still in bussiness?
grantspain
« Reply #10 on: February 10, 2015, 06:51:13 pm »
I think they went out of business last year but there must be their products around still
http://www.casinovendors.com/vendor/gd-tronics/
Their products were in the u.k on games like skillball bingo and pocket money pool,they also made a replacement 29" monitor for sega medium res games like sega rally
They were actually pretty good monitors
