Author Topic: My Cabinet only has one speaker  (Read 1782 times)
« on: January 19, 2015, 10:52:56 am »
On my Jamma cabinet, there are two speaker holes, but only one speaker under the hood.
Is there any benefit in adding a second?  Cab will be running 90's titles, but there is a chance a Cave shooter will make it in.
Also there are only two wires coming up from the Jamma harness, what type of magic fu would be required to wire up an additional speaker if it was warranted?
Re: My Cabinet only has one speaker
« Reply #1 on: January 19, 2015, 11:56:48 am »
That's called mono. Not all pcbs provide stereo sound. For adding a second speaker, just follow the jamma pinout and tap in to the appropriate wires, or jumper over from the existing speaker for dual mono.
« Reply #2 on: January 19, 2015, 12:02:21 pm »
ewww Mono, I had that once, I wouldn't want to catch it again  ;)
I like the jumper over idea for Dual Mono, although I'd probably go ahead and run the wiring for stereo and leave it unconnected to future proof it.
Louis Tully
« Reply #3 on: January 19, 2015, 12:11:37 pm »
« Last Edit: February 12, 2015, 07:11:38 pm by Louis Tully »
« Reply #4 on: January 19, 2015, 12:17:15 pm »
If you want to get really clever... You can install a switch, so in one position you have dual mono and in the other you've got stereo.
johnrt
« Reply #5 on: January 19, 2015, 12:44:25 pm »
Here's a potential project for somebody:
http://www.google.com/patents/US5655025
« Reply #6 on: January 19, 2015, 01:20:47 pm »
I love this forum
