Author Topic: arcade VGA and windows.. curled?  (Read 1608 times)
delta88
  • Last login:July 14, 2026, 12:34:36 am
  • This place is still here?
« on: December 19, 2003, 02:30:38 am »
well I have an arcade vga and it is hooked up to a jpac and then to the wells gardner 25" like a k71....???  but now if I adjust the screen so that the vertical holds in windows when I start a game it flips and ok well I can adjust it to play some games.. but now the games play and fit the screen nicely but when I exit back to windows the bottom of the picture is "curled" at the bottom.... or it kinda looks bunched up.. is this a driver problem or is the monitor not compatable? its kinda wierd.. I had a heck of a time setting up the last one...
thanks for any help
thx
Re:arcade VGA and windows.. curled?
« Reply #1 on: December 19, 2003, 04:53:04 am »
Does the v-hold need adjusting?  Perhaps the image does not quite 'settle' in the correct spot.  Try tweaking the v-hold VERY carefully - it may need a clean if the monitor is old.
