Author Topic: Rowe cd-100a jukebox keeps playing cd after cd without ever stopping  (Read 2719 times)
ransome
  • Last login:March 01, 2016, 06:42:44 am
I just picked up a Rowe cd-100a jukebox for cheap . After plugging it in , it will play a cd track then pick up another . I think it is playing favorites ,it will never stop however . If I make a selection , it will play that selection then go back to playing what it wants. I tried the reset , how do I clear the memory on this box?
 I own a manual but cant find where to clear memory. cdm12
« Last Edit: January 11, 2015, 03:33:54 am by ransome »
ransome
Re: Rowe cd-100a jukebox keeps playing cd after cd without ever stopping
« Reply #1 on: January 11, 2015, 03:35:40 am »
After reading the manual more closely ,,,Looks like I just need to go into service mode , autoplay then clear programming .Ill try that tomorrow
ransome
« Reply #2 on: January 11, 2015, 08:19:44 pm »
 I went in to the service mode . turned autoplay to off. Turned the jukebox to normal mode and it is still constantly playing , but any selection I make , it will play it . How do you do a master reset on this unit , maybe start from scratch
thanks Gregg
jdemarti
  • Last login:May 31, 2022, 10:57:25 am
« Reply #3 on: January 16, 2015, 08:19:35 pm »
There is a clear selections option in the programming. If that does not work, try pulling the battery out of the CCC for a couple minutes (soldering may be required). When you reinstall the CCC and power on it should load the default configuration.
ransome
« Reply #4 on: January 16, 2015, 09:09:00 pm »
Hi
 Thanks For the reply.
 I ended up doing a full reset  , that finally  made it work like it should
Gregg
