Author Topic: connecting x-gaming coin door to tank stick and playing pinball  (Read 1732 times)
knightrdrx
  • Last login:June 06, 2020, 10:45:36 pm
« on: January 10, 2015, 11:46:32 am »
I'm sure x-gaming has the answer but I can't wait til Monday!  ;D
My coin buttons are 5 and 6 (on the top) now so as not to interfere with the pinball side buttons
But now I'd like to add a coin door for appearance.  I don't have to hook it up but I might as well but it has to be connected to the side button.
So...then I'd have to make the side buttons the coin buttons. But won't the flipper add a credit then?  I don't understand this.  Doesn't seem to be a way to have both unless I pull the button out of the hole and swap it with the one on top ('5' default)....or ...just make a different coin button for the pinball...makes it a tad bit confusing. I (the arcade master) know how to use everything though! My friends need an instruction manual haha.
jeremymtc
  • Last login:June 29, 2026, 10:03:14 pm
Re: connecting x-gaming coin door to tank stick and playing pinball
« Reply #1 on: January 10, 2015, 12:51:35 pm »
There are additional unused inputs available in the X-arcade encoder, iirc. You can wire your new inputs to those, and just map the function as needed in whatever emulators you're using.
knightrdrx
« Reply #2 on: January 11, 2015, 11:38:55 am »
I don't know what you mean.  There's extra connectors not used that are also tied to a keyboard command?  I could add buttons too if needed??
  • Last login:Today at 08:26:31 pm
« Reply #3 on: January 11, 2015, 11:57:43 am »
Search for my posts with "MagnaSave" for a chart of the overlapping keys used in MAME and Visual/Future Pinball and how to wire switches "backward" to piggyback on other switches. (2 buttons, 1 encoder input)
The only thing to watch for is that the X-Arcade encoders use an isolated common for each wire group instead of one common ground.
