Author Topic: ROWE AMI CD100A - Auxiliary input options  (Read 5949 times)
foxman
  • Last login:January 07, 2015, 08:38:25 pm
« on: January 04, 2015, 04:04:07 pm »
Hello out there,
 I'm looking for a resource for an auxiliary input for my CD-100A. I'd like to run house music through an aux input, and then when a selection is made on the juke, I'd like the "house music" to switch off, and the juke to play the selection(s). Does the amplifier board already have this capability, or do I need to get an aux input board? Where to get one? I would like to have dual RCA type inputs so I can plumb in either a tuner / iPod / Bluetooth receiver to run the house music.
Any help / suggestions are appreciated!
Ken Layton
  • Guru
  • Technician
Re: ROWE AMI CD100A - Auxiliary input options
« Reply #1 on: January 04, 2015, 11:36:40 pm »
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
« Reply #2 on: January 05, 2015, 11:03:13 am »
Hi Foxman,
If you can not locate one of the Rowe Ami interfaces  I do have one of the 21639701 kits in stock (new old stock) including the instruction manual.
I also have the 60792702 preamp accessory boards.
Regards
Alan
Alan Hood
ami-man
UK
installs
  • Last login:July 10, 2018, 02:55:38 pm
« Reply #3 on: June 05, 2018, 02:25:50 pm »
Hi Foxman,
Regards
Alan
Alan Hood
ami-man
UK
Alan, Do you still have the 60792702 preamp accessory boards?
I would love to buy one from you if so.
« Last Edit: June 05, 2018, 02:28:11 pm by installs »
ami-man
« Reply #4 on: June 08, 2018, 06:42:16 am »
Hello Installs,
I have only the earlier 6-07442-01 board which was designed to work with the 125 or 130 watt amplifiers used on the R-84 to R-94 jukeboxes.
It is basically the same board but it has a 3 pin auxillary connection rather than a 5 pin.
Regards
Alan
Alan Hood
ami-man
UK
