Author Topic: Cga to VGA converter gbs8220 help  (Read 1137 times)
Mthartman
  • Newbie
  • Last login:January 03, 2015, 07:22:45 am
« on: January 02, 2015, 06:29:13 pm »
I have everything wired up and I'm having what I believe is a sync issue. The instructions state you may have to connect both yellow and gray wires together from the adapter harness to the one solid white wire on tha jamma harness. If I do that I get a screen shot. If I only connect the yellow wire I get a constant roll. Any help?
