Author Topic: Need GOOD Defender marquee  (Read 2204 times)
paigeoliver
  • Awesome face!
« on: December 18, 2003, 04:50:55 am »
Topic says it all. The one in the vector library would pe perfect, except that it is chopped off a couple inches on each side.
mahuti
Re:Need GOOD Defender marquee
« Reply #1 on: December 18, 2003, 12:28:09 pm »
The one in the library is identical to my original as far as spacing, and pretty close as far as content.
Maybe there were different versions, but versus mine, it's about as dead-on as can be.
TheTurk
  • Last login:December 09, 2004, 09:33:15 pm
paigeoliver
  • Awesome face!
« Reply #3 on: December 19, 2003, 12:34:12 am »
Maybe there is a problem viewing the file then, but looking at it here at work with Ghostscript it is totally missing everything to the left and right of the letters, actually starting about a half inch after the D starts and ending a half inch before the the R should end.
I probably will just end up buying one.
« Last Edit: December 19, 2003, 12:34:47 am by paigeoliver »
tbombaci
  • Last login:October 31, 2024, 01:32:56 pm
« Reply #4 on: December 19, 2003, 12:36:33 am »
I did the marquee. It is dead on. Maybe Ghostscript has a problem reading AI 10 files.
I can send you a PDF or an EPS if you like.
-Tom
paigeoliver
  • Awesome face!
« Reply #5 on: December 19, 2003, 01:28:00 am »
A PDF would be great.
tbombaci
« Reply #6 on: December 19, 2003, 11:51:06 am »
When I opened the file, I saw the problem right off the bat. The file was set up as 18x18. When Ghostscript parsed the file, It disregarded the information outside of the bounding box.
I sent you the PDF too.
-Tom
paigeoliver
  • Awesome face!
« Reply #7 on: December 24, 2003, 05:02:52 am »
Thanks for the PDF, I had it printed up at Kinko's and it looks great.
