Author Topic: Modeline for Dolphin  (Read 4306 times)
retrorepair
  • Last login:July 06, 2025, 06:47:43 pm
« on: December 09, 2014, 06:15:41 pm »
Since Gamecube resolution (at least for interlaced modes so I understand) is 640x528@60hz (50hz for PAL), how do I go about adding that modeline?
I've tried a lot in the past to understand how these modelines work but I just can't figure it out.
I'm using the "super" resolutions (I think, it's been a while) from when windows 7 support was added (about UME 0.153?).
« Last Edit: December 09, 2014, 06:40:20 pm by retrorepair »
My arcade racing setup:
My Youtube Channel: http://www.youtube.com/user/RetroRepair
My Twitter: http://twitter.com/retrorepair
Calamity
  • Moderator
  • Last login:Yesterday at 05:48:55 pm
  • Quote me with care
Re: Modeline for Dolphin
« Reply #1 on: December 09, 2014, 06:42:57 pm »
Add that mode into ReslList.txt and run VMMaker:
http://geedorah.com/eiusdemmodi/forum/viewtopic.php?pid=327#p327
« Last Edit: December 09, 2014, 06:46:53 pm by Calamity »
Steps to create a log:
retrorepair
« Reply #2 on: December 09, 2014, 06:54:44 pm »
I did try that but it says it's redundant  ???
Calamity
  • Moderator
« Reply #3 on: December 09, 2014, 06:58:23 pm »
Attach your ModeList.txt file here.
retrorepair
« Reply #4 on: December 09, 2014, 07:04:58 pm »
It's in the modelist.txt but it's still dismissing it as being redundant  ???
Calamity
  • Moderator
« Reply #5 on: December 09, 2014, 07:12:58 pm »
Ok I see, you simply can't get 528i@60 with 15 kHz, it's clearly out of range. You must create that one as PAL (50 Hz).
retrorepair
« Reply #6 on: December 09, 2014, 07:19:03 pm »
Oh right, yeah I just changed it to 50hz and it added it fine.
It must work in 15khz though or else gamecubes wouldn't work on US TVs, is it just a limitation in the graphics card?
retrorepair
« Reply #7 on: December 09, 2014, 07:42:59 pm »
Ok now I have played with it in arcadeosd I can see it's way out of range. I still don't understand how US consoles can display it on a normal TV, or PAL consoles displaying 60hz.
adder
« Reply #8 on: December 09, 2014, 08:08:27 pm »
Quote from: retrorepair
640x528 is the internal resolution. this is changed depending on if you then are running pal or ntsc
"The internal resolution of the GC/Wii is 640 x 528. This is the resolution that the game is rendered at whether it is a PAL or an NTSC game. A PAL GC/Wii will then stretch that to 768 x 576 while an NTSC GC/Wii will stretch it to 640 x 480 before output.
Dolphin stretches it to whatever you set your fullscreen or windowed resolution to be. It doesn't use the PAL or NTSC resolutions as output unless you specify it yourself."
source: https://forums.dolphin-emu.org/Thread-pal-vs-ntsc-dolphin-resolution
retrorepair
« Reply #9 on: December 09, 2014, 09:23:12 pm »
Well that makes a lot of sense. The PAL resolution looks much more like the real thing and Dolphin actually runs it at 50 frames per second too.
I still get tearing but I guess my system just isn't up to the task. Thanks all, Calamity, your support is second to none.
haynor666
  • Last login:Yesterday at 12:16:38 pm
  • retro maniac
« Reply #10 on: December 10, 2014, 01:43:50 pm »
Tearing will always visible unless Dolphin has double/triple buffer or could sync to vertical freq just like MAME.
That reminds me that is time to test new Nestopia in my arcade PC.
adder
« Reply #11 on: December 10, 2014, 01:54:24 pm »
