Author Topic: WG K7000 arcade monitor won't center  (Read 1752 times)
actman
  • Last login:April 18, 2024, 12:17:27 pm
« on: December 04, 2014, 08:10:31 pm »
When I play a Mame game at its proper resolution I can't seem to move (center ) it on the screen.
My pot will turn all the way moving the screen top up to about 1" from the top.
I can move it down but won't go up far enough . I think it's called Vertical Rastor position .
I am using an Arcadevga card. Is this a resolution issue I can set or something needs fixing on my monitor?
lilshawn
  • Last login:Yesterday at 05:35:43 pm
Re: WG K7000 arcade monitor won't center
« Reply #1 on: December 05, 2014, 03:25:38 pm »
give the "50/60hz" pot a tweak. that should get you lined back up again. they can get out of whack.
actman
« Reply #2 on: December 05, 2014, 09:24:40 pm »
I will try that on Monday. Hope that does the trick. I put back the Marvel vs Capcom consol that came in the cabinet and it has the same issue.
