Author Topic: Power Switch  (Read 1555 times)
fsa317
  • Last login:January 02, 2015, 08:15:48 am
Power Switch
« on: December 01, 2014, 09:47:45 am »
Hi, I'm building my cabinet for a raspberry pi based unit.  The pi, monitor and marquee I'd like to have on one power switch to power down / up the unit.  Basically I was thinking of putting a power strip inside the cabinet but wanted a off/on switch mounted externally.  I've been searching and haven't found a power strip that has a switch that can be mounted separately?  Any idea where I can find what I'm describing?
jdbailey1206
Re: Power Switch
« Reply #1 on: December 01, 2014, 10:18:23 am »
Go here and start reading @ IEC Fused Power Inlet with a Lighted Switch.  Hope this helps.
fsa317
Re: Power Switch
« Reply #2 on: December 01, 2014, 10:21:08 am »
Perfect just what I was looking for.
fsa317
Re: Power Switch
« Reply #3 on: December 01, 2014, 12:15:09 pm »
Would love to get others thoughts on another idea - one that doesn't require as much wiring.  What about buying something like this:
http://www.amazon.com/Belkin-F7C016q-Conserve-Power-Switch/dp/B005MYN3OO/ref=pd_sim_e_5?ie=UTF8&refRID=06FMAKDDMP1ASP3EHE81
Run an extension cord with a female end inside the cabinet and mount this so that only the switch is exposed from the cabinet.
What do you think?
BorgDog
Re: Power Switch
« Reply #4 on: December 01, 2014, 12:25:30 pm »
That would work, just not as clean and to unplug you have to open the cabinet.  Hard part would be making the switch accessible and looking nice and secured solidly.
My Projects:
keilmillerjr
  • Web Developer.
Re: Power Switch
« Reply #5 on: December 01, 2014, 02:02:24 pm »
Use the PiSupply on off switch and wire it to an arcade button or whatever you choose. Run power from a usb smart strip such as the ecostrip to turn on accessories with the raspberry pi. Add a proper female
receptacle on the back of the cabinet so you can have a removable power cord to the outlet. Search on Amazon. I forgot the correct name.
https://www.pi-supply.com/product/pi-supply-raspberry-pi-power-switch/
http://www.m.ecostrip.com
