Author Topic: MDF vs PVC  (Read 5802 times)
MadMike
  • Last login:March 04, 2017, 07:13:31 pm
MDF vs PVC
« on: November 23, 2014, 06:37:29 pm »
I see a few people are selling PVC Foamex bartop kits which are generally a bit more expensive than MDF.  Is this a good material to use?  Is it as rigid at MDF?
« Last Edit: November 23, 2014, 06:39:50 pm by MadMike »
Generic Eric
Re: MDF vs PVC
« Reply #1 on: November 23, 2014, 10:03:53 pm »
Do you have a link?
Foamex?
rovingmind
  • Last login:October 17, 2023, 11:13:48 pm
  • If you only knew the POWER of the Dark Side
    • rovingmind
Re: MDF vs PVC
« Reply #2 on: November 24, 2014, 12:14:14 am »
well, a quick google search of foamex panels brings up that its pvc panel material used for sign boards.  The thickness listed by the manufacturer (FXI now) shows a max thickness of 10mm.    It should be quite a bit lighter than an MDF bartop.  I'm guessing that its probably about as sturdy as one made out of Plexi, and as such would be dependent upon how much bracing was built into it.    If you drop the foamex name and just toss in PVC to the search this comes up.
http://www.ebay.com/itm/2-Player-PVC-Bartop-Arcade-Cabinet-Suitable-4-MAME-HYPERSPIN-JAMMA-Project-/221592082261?pt=UK_Video_Games_Coin_Operated_MJ&hash=item3397ead755
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHHHH!!!!!
MadMike
Re: MDF vs PVC
« Reply #3 on: November 24, 2014, 06:37:22 am »
Yeah. they are the PVC kits I'm talking about.  I heard the name Foamex in relation to one of those kits somewhere.  They are around £30 more expensive than MDF.  Yes I think they are around 10mm but not 100% sure.  I guess the material just costs more than wood, or perhaps because you don't have to paint it (if you want it white).  Just wondered if anyone had used it and how good it is.
Re: MDF vs PVC
« Reply #4 on: November 24, 2014, 09:21:25 am »
I've only ever seen those listed for sale in England.
